Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - toyota truck rear axle
Old 12-11-2012, 01:22 PM
Studebaker Studebaker is offline
Rear end swap.
What do you mean by "smoked my 9 inch rear end"? Break a Pinion, axle bearing, or? If you did not destroy the housing, it would probably be cheaper to rebuild the diff and replace whatever else broke than doing the switch. Toyota does make good rear ends but I don't see how this could be a cost effective swap compared to rebuilding the Ford 9".
