Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - toyota truck rear axle
Old 12-14-2012, 10:39 AM
prostreet6t9's Avatar
prostreet6t9 prostreet6t9 is offline
Differential/Driveline
The axles on the Toyota are actually pretty stong.. If you want the third member to live you need to keep higher gears in the third member.410/456 seem to hold up pretty good. If you do to 488/513/529/571 your begging for breakage.
