Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - TPI 305 need rebuild.... time for 350?
Old 05-18-2012, 08:11 AM
zildjian4life218's Avatar
zildjian4life218 zildjian4life218 is offline
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Originally Posted by AutoGear
If he wants to invest some money into it and youre going to try your hand at burning, you might want to see how he feels about picking up a different manifold and heads. Over on thirdgen.org, you can always find someone doing a LS1 swap, and there usually a few minirams, ported OEM intakes, worked iron heads, 58cc aluminum heads etc on the for sale boards. Also, there are some racing circles that need date coded 305 blocks, so it should be worth more than scrap.
awesome thanks for that advice. Ill definitely take a look. I just figured with the way I wanted to build the engine his transmission and rearend should last longer lol.
