TPI 305 need rebuild.... time for 350? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2012, 07:01 AM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Okay... I have a friend that wants me to rebuild the motor out of his 86 f-body. Its a 305 TPI with an automatic transmission. He was having issues with it over heating and drove it anyways and now the engine runs pretty rough...
Im thinking instead of rebuilding the 305 why not swap in a rebuilt 350... stock rotating assembly just new rings and bearings maybe a small cam and try to find a set of those 305HO 416 heads and rebuild those for him. Of course I will need to burn a new chip for the ecu and add some larger injectors..
What would you guys do if you had a 305 that needed rebuilding. My vote is swap a 350 into its place. His budget is between 1000-1200 and I think I can make it work once I get the quote back from the machine shop.
Old 05-16-2012, 08:10 AM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
I'd go 350 but not sure about the small heads.
Old 05-16-2012, 08:47 AM
Listen and Learn
Wiki Edits: 7
I have heard quite a few good things about these heads with some minimal port work done to them... plus with the tpi intake this is gonna be built for low end torque, those intakes aren't really known for their high rpm breathing abilities.
Old 05-16-2012, 09:23 AM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
TPI is no good after 4800 rpm's but I found restrictions can really choke it off.
Intake and exhaust on my truck TPI were restricted and robbing a bunch of torque and HP.
Just seems smaller valves would do the same.
Second entry down shows the difference in dyno pulls after removing restrictions. Maybe these heads are a totally different deal, but in theory restrictions cost torque and HP.
TPI DYNO PULLS
Old 05-16-2012, 10:58 AM
my87Z's Avatar
Veteran/Firefighter-Paramedic
personally i would find a complete vortec 350, inspect it, and then change it to a carb set up, ditch the ECU. he should have a 700R4 trans which can easily be adapted to a carb set up with the detent (TV) cable.
Old 05-17-2012, 09:28 AM
Listen and Learn
Wiki Edits: 7
This will definitely be a consideration but I think he wanted to keep it efi.
Old 05-17-2012, 09:33 AM
Listen and Learn
Wiki Edits: 7
TPI DYNO PULLS
I think the posts I have seen on these heads involved installing 1.94" intake valves
Old 05-17-2012, 10:08 AM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
You will have to change the ecu if you change to a 350.
Old 05-17-2012, 10:21 AM
Listen and Learn
Wiki Edits: 7
Not just reprogram it for the larger injectors and displacement but actually physically change it?
Old 05-17-2012, 10:26 AM
S10 Racer's Avatar
Either or. It may be cheaper to find one in a junk yard and just replace it as opposed to reflashing it.
Old 05-17-2012, 10:27 AM
Listen and Learn
Wiki Edits: 7
http://tpiparts.net/305_tpi_to_350_tpi_conversion
says just gotta change the prom, knock sensor, esc module and injectors so the efi wont be bad to do. I have been looking for an excuse to buy an emulator and chip burner for awhile so now I have that excuse
Old 05-17-2012, 01:59 PM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
Bigger valves would help for sure.
Old 05-18-2012, 05:23 AM
Rhansen's Avatar
Footbraker
You won't necessarily even have to change the ECU/Prom or injectors. I swapped in a 350 (crate motor for an 87 pickup) into my 87 IROC back in 1991. This was a MAF setup not speed density and all I did was use an adjustable fuel pressure regulator to bump up the pressure to 50 psi. Only other mods were edelbrock headers, 3" single exhaust, and a homemade ram air setup.
It worked flawlessly until I swapped cams. IIRC the new cam was a Blue Racer dual pattern with 112 lsa, 204/214 duration and .435/.465 lift. After the cam swap the car would surge a bit at idle and sometimes stall sitting at lights. Had a custom PROM burned at Arizona Speed and Marine which cured the idle problem but made the mpg nosedive and made no improvement in ET/mph at the strip.
I would think with the right cam and an adjustable regulator on a mass air motor you could do the swap without new injectors or a prom.
Old 05-18-2012, 07:13 AM
If he wants to invest some money into it and youre going to try your hand at burning, you might want to see how he feels about picking up a different manifold and heads. Over on thirdgen.org, you can always find someone doing a LS1 swap, and there usually a few minirams, ported OEM intakes, worked iron heads, 58cc aluminum heads etc on the for sale boards. Also, there are some racing circles that need date coded 305 blocks, so it should be worth more than scrap.
Old 05-18-2012, 08:11 AM
Listen and Learn
Wiki Edits: 7
awesome thanks for that advice. Ill definitely take a look. I just figured with the way I wanted to build the engine his transmission and rearend should last longer lol.
305, 350, tpi
chevy 350 tpi rebuild 86/outlaw Engine 7 02-25-2011 05:33 PM
305 TPI to 350 TPI Parisienne70 Engine 1 05-06-2008 01:23 PM
305 tpi heads on 350 block need4superchevy Engine 3 08-07-2007 09:38 PM
305 TPI swap to a '76 350, can it be done? 70bird Engine 12 12-22-2004 12:39 AM
Tpi 305 To 350 Teejay68 Engine 3 11-26-2004 12:43 PM
