TPI 350 Distributor installation question? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2003, 01:55 PM
Question TPI 350 Distributor installation question?
I have a TPI 350 from a 1988 Pontiac Firebird it was installed into a S-10 truck. During installation I broke the distributor and replaced it with a junk yard unit. I must not have installed it correctly because the motor will not idle or rev up without missing very badly. I know that #1 cylinder should be at TDC, but where should the rotor point? I must have the distributor gear and the cam gear meshed in the wrong spot. I looked at past posts and only found one that helped. I am asking for more specific information. Also the TPS, MAF, cap and rotor are all good. Thanks <img src="graemlins/evil.gif" border="0" alt="[evil]" />
Old 04-04-2003, 03:19 PM
milner's Avatar
Post
#1 should be on tdc on compression stroke. rotor should be pointing at #1 plug wire. you have it running now, probably just needs timing adjusted. good luck!
Old 04-04-2003, 04:17 PM
Post
To be more specific I want to know where #1 is as if you were looking at the face of a clock. The rotor is the hand of the clock and the firewall is 12 the radiator is 6. Can #1 be in any position or at a certian "hour". Hope this makes sence. Thanks
Old 04-04-2003, 11:57 PM
aka Duke of URL
Arrow
No. 1 should be at approximately the 5 o'clock position.
Old 04-05-2003, 06:57 AM
Post
Thank you guys alot as soon as it stops raining
I'll give it a try
Old 04-06-2003, 11:55 AM
Tom Tom is offline
Post
It doesen't really make any difference where no 1 is as long as the timing and firing order is correct
Old 04-06-2003, 04:25 PM
Post
Today I tried to reinstall the distributor but was unsuccessful in getting it to run right. Now the motor will not even start! My friend told me over the phone that I am surely 180 degrees out. And that the motor compresses air on both the intake and exhaust stroke. So that was probably where I got mixed up. Who knew that the timing was such a hard thing to get right? Now I am going to try it again... Thanks for your help please keep the ideas coming.
