tpi to carb - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2010, 04:58 PM
tpi to carb
hey im doing a swap from 305tpi to 350carb with twin turbo my question is will i need a return fuel line im eliminating the factory lines and going all braided into regulator thanks
Old 04-08-2010, 05:46 PM
If your regulator doesn't use a return, it won't be needed. But, if you're using the factory fuel pumps, I'd suggest some sort of regulator that does use a return as the factory pumps don't take kindly to deadhead pressure over time. The return let's the pump relax a bit under lower load.
Old 04-09-2010, 10:42 PM
fast68's Avatar
likes chevy trucks & boobies
return to fuel sender unit yes, even on carb ones.,
TPI pumps too muh pressure for a carb so a regulator will be needed, or swap to a carb sender unit, or if using a mechanical pump then just remove the pump from the sender unit and replace with a length of 3/8" hose to serve as fuel pick up in the tank, or you could get away with a TBI pump on the TPI hanger.
good luck
Fire in Carb juiced66malibu General Rodding Tech 1 01-02-2010 01:08 AM
Carb Recommendation please My68Vette Engine 29 07-03-2009 05:14 PM
Holley carb has me at wit's end cool rockin daddy Engine 23 06-02-2005 02:38 PM
'87 tpi to carb newcustom Engine 11 07-02-2004 06:26 PM
Better? Carb or TPI chevcamz28newbie Engine 3 07-26-2003 04:32 PM
