TPI Coil Wire - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2007, 03:46 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
TPI Coil Wire
I have a 92 TPI unit that I'm wiring up. I have a pigtail that fits the distributor but the colors are off. The 2 wires from the coil are pink and white. Does anyone know if I should hook up the pink from the coil to the yellow wire on the right or to the black on the left?
Thanks, Pugsy
Old 07-10-2007, 04:50 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
I have a 56, a 63, a 58 and an 80...what wire goes to the alternator the grey or blue??
Now you see how easy that is..
You have a 92 WHAT???
If it is GM, traditionally, the pink is power, the yellow may be Pulsed low signal pickoff..but without looking it up for sure, I couldn't tell you..
Doc
Old 07-10-2007, 06:41 PM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
The TPI is from a 92 Firebird or Trans Am.The wires go from the top of the remote coil to the module.I don't have the car, just the TPI that I will be installing on my 350 in my pickup.As for wires from the alternator???? .I will be using the wires that are already there.
Cruise Control Compatibility with LED's? cboy Electrical 44 10-01-2010 12:08 PM
hei distributor coil wire bigvan98 Electrical 1 06-20-2007 09:57 PM
starter solenoid shorting ignition junkyardjeff Electrical 5 03-24-2007 04:15 PM
Postive ground but negative coil, strange one Nightfire Electrical 21 04-19-2006 05:20 PM
Elec. fuel pump relay needed? upstand2 Electrical 4 05-10-2005 05:21 AM
