TPI computer setup for truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-04-2004, 04:58 PM
11secmudtrk's Avatar
mudbogger
Which TPI set up would be the easiest to fit on a 93 chevy truck, and what would be the best year camaro, corvette, ect. to pull the computer from?
Old 12-05-2004, 02:13 AM
Siggy_Freud's Avatar
A computer for a 93 chevy pickup.
What are you trying to do? MUST HAVE MORE INFO!!!!
Bringing history and technology together.
Old 12-05-2004, 12:25 PM
mudbogger
edit
Old 12-05-2004, 12:30 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
Not enough info. old style tpi? mass air flow?
Old 12-05-2004, 01:38 PM
mudbogger
Old 12-05-2004, 02:02 PM
edge's Avatar
Time is short, are you ready?
Is your 93' a stock TBI setup? If it is, your swap will be like the one I am about to do over the next few weeks.
I have a 94' Suburban and will be installing the TPI from my 91' GTA in a few weeks. You need to make a phone call to Street & Performance before proceeding with this project. They have done this and have all the parts and technical support you will need. Ask for Jason.
I just ordered a stand alone computer (weatherproof for underhood installation), TPI wiring harness, an integrator harness that jumps between the new computer and the original computer. The original computer is left intact with no chip change to run other aspects of the truck, including but not limited to ABS, transmission 4L60E, etc. The two must be able to communicate since the trans needs engine load information to function (TPS, etc.) They will sell you a custom chip, and a TPI knock sensor. I was told that a TBI knock sensor is different. You will need a new throttle cable to work with the TPI. In order to fit the TPI unit, you will need accessory brackets off a serpentine belt 5.7L Camaro/Firebird. And don't forget a new air cleaner. S&P can sell you all this stuff.
A high pressure in-tank fuel pump is necessary. You can get one from a local parts store. I installed one that fits a stock 91' Firebird GTA with a 5.7L. It is a direct replacement, including the wiring plug.
Since my TPI unit is already apart, I will also have my injectors cleaned by S&P.
I plan on documenting my swap with pictures, etc. and post it on my website. Good luck, Ed www.edgesz28.com
__________________________________________________
Who is Jesus?.
Old 12-12-2004, 03:04 AM
custom classic truck magazine did a few articles on tpis that were very good one callled the hows and whys of tpis. it answered all those questions. the "waterproof" computer is nothing more than a factory vette comp it was mounted in the engine compartment instead of the pass. kick panel(camaro)..
the injectors are one of three 305,350, vette 350 something like 19.5,21.5, and 24.5 lb hr. i read that the computers can be re programmed by s&p even a 4 or 6 cyl comp. .. they say the 350 computers all have the antitheft chip and if installed alone will only run for 10 seconds and shut down. VAT chip i think but the 305 computers dont have this and they can program them to run the 350 injectors. from what ive found s&p are the kings of knowledge for gm tpis and can give you all the info you need.
ive also heard that if you have a maf model tpi you absolutely must use a painless wiring harness to bypass the maf and run properly unless youuse the og harness with an out dated maf system. the newer speed density versions are supposed to be 100 times better, and the 9 injector models are outdated and can be converted to an 8 injector cold start by using the new computer and plugging the 9 injector holes in the rail and runners with parts from S&P.
EDGE ---
who is jesus ??
jesus is and was a real person who walked the earth. jesus died for you and me, for every sin every man has ever done. jesus died so you and i could be forgiven and be lifted up to heaven once we parish(all hot rods must be left behind at this time, sorry) he lived to forgive every and any one who believes in him, and if you dont well ........the elevator is going down. so this is where we come in to go out in to all the world and spread the word of jesus..there is too much junk going aroung about religion and no one knows whats behind christmas whats this world coming to?
Old 12-12-2004, 11:11 AM
mudbogger
so i can get the computer out of a v6 car and just buy the injector harness, throttle body, and get the chip reprogramed right? basically something like this http://hotrodders.com/attachment.php?s=&postid=224052
Old 12-14-2004, 11:02 PM
11 is that your engine?? sweet lookin
the article i have says yes on using a 6shooter computer but the chip has to be reprogrammed and can be custom progammed to give you exactly what you want. it even lists part #s and what years to yank them from, check out the info at classictrucksweb.com go to the search box on the bottom left of the page and search TPI and the top 2 articles tell you everything about tpis. also go to S&P website hotrodlane.cc or .com and they have a video you can download, my computer doesnt have the memory to do so. hope this info helps
