Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - TPI electric Fan HELP!
Old 07-30-2005, 09:55 PM
boneyard Buick's Avatar
boneyard Buick boneyard Buick is offline
1988 tuned port injection setup with stock electric fan. i went out and bought a new fan, that does more RPM to keep the motor cooler. I noticed that on the stock fan it had a plug directly on the casing...i want to install the new fan so is it possible to just cut the stock plug from the harness and replace the plug with a new one?? like add the male end to the fan and the other plug to the harness? would that work? or is there something in the stock fan that it needs? Also.... is the stock electric fan good in irocs?? doesnt it turn on when the motor reaches a certain temperature? ive heard of people just re-wiring the fan to a switch so its always on, whats your guys' ideas/oppinons???????
Ryan350 :thumbup:
