Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - TPI electric Fan HELP!
Old 07-31-2005, 12:21 PM
Siggy_Freud's Avatar
Siggy_Freud Siggy_Freud is offline
When you get a chip burned for your setup, you can tell the guy you want the fan set to come on at a lower temp. Just make sure you run a thermostat that will compliment the newer temperature settings.
Bringing history and technology together.
