TPI electric Fan HELP! - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-30-2005, 08:55 PM
boneyard Buick's Avatar
1988 tuned port injection setup with stock electric fan. i went out and bought a new fan, that does more RPM to keep the motor cooler. I noticed that on the stock fan it had a plug directly on the casing...i want to install the new fan so is it possible to just cut the stock plug from the harness and replace the plug with a new one?? like add the male end to the fan and the other plug to the harness? would that work? or is there something in the stock fan that it needs? Also.... is the stock electric fan good in irocs?? doesnt it turn on when the motor reaches a certain temperature? ive heard of people just re-wiring the fan to a switch so its always on, whats your guys' ideas/oppinons???????
Ryan350 :thumbup:
Old 07-31-2005, 01:56 AM
Siggy_Freud's Avatar
Yes you can add the plugin onto the new harness. Just make sure you have the power and ground wires in the right places.
The fans are programmed via the chip to come on and off at certain temperatures. You CAN wire them to a switch but I really dont see much point as long as everything is setup properly.
Bringing history and technology together.
Old 07-31-2005, 02:25 AM
alrighty
thanks
ya i was just wondering about the switch thing, cuz i read somethin a while ago on a different site, and they mentioned a fan being hooked to a switch instead. Anyways thanks
Ryan350 :thumbup:
Old 07-31-2005, 07:38 AM
I like to wire it to a switch and still keep the auto kick on feature. That way if you know your going to be heating up you can pre-turn the fan on. I have always thought that they wait too long to bring the fan on. When I had my celebrety the fan came on at 240 so I put a switch on it and at 200 I would turn it on. That way it never got to 240. But when my wife was driving and she never looks at guages it would still come on at 240 to protect the engine. I even tried to get a lower temp switch but couldnt seem to get one from the local stores.
Old 07-31-2005, 12:21 PM
When you get a chip burned for your setup, you can tell the guy you want the fan set to come on at a lower temp. Just make sure you run a thermostat that will compliment the newer temperature settings.
Electric Fan Temp. Sensors horvath Electrical 26 04-26-2011 03:04 PM
Electric Fan Recommendations? Malibu73 Engine 18 06-01-2005 03:26 PM
Clutch Fan malibuman66 Engine 18 01-01-2005 10:09 AM
electric fan or clutch fan?? mancinator Engine 4 06-02-2004 02:49 PM
EZ-Wire : Fan Connection horvath Electrical 11 03-28-2003 10:35 AM
