TPI Electric speedo?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-18-2009, 12:31 PM
Bluepen's Avatar
Just a firefighter
Last wiki edit: How to title a hot rod
Last journal entry: New rear rollpan installed
Wiki Edits: 2
I've got a small problem with my TPI speedo, it won't work!!!!!!!
It's on a TH400, I've checked all the wires twice and they are correct. The odometer comes on, the settings show up but the needle has never moved and it won't calibrate when I take it out to set the speed. I'm thinking it's something to do with the trans speed sensor but I'm not sure. When I got it I took all the numbers off the trans down to a friend of mine he owns a trans shop and they show it to be a '77 TH400, but it has an electronic speed sensor and they don't show up in any parts listing until 80 something. Thats the part that has me confused. I'm not real good with electonics so any help would be great.
Thanks guys
Old 01-21-2009, 09:11 AM
New Member
We use Faria gauges in our builds, pretty much the same as TPI. Its probably the sending unit. Is it a hall effect( 3 wire) or optical style? Here is what I would check:
Attach the signal sending wire (3 wire right?) to a multi-meter and see if you get a signal when you are driving.
If not, check that you are getting voltage to the speedo sender, and a ground with the multi meter.
Make sure the drive tang is engaed into the trans. Sometimes the tang will get hung up on the trans input, its a pretty small hole (.104x.104)
That would be a good place to start.
the stock sender may work, you just need to know if its a hall effect or optical style.
Mark
Old 01-22-2009, 01:25 PM
Bluepen's Avatar
Just a firefighter
Wiki Edits: 2
Mark just to let you know I did find out what the problem was. As I thought the dip---t PO put an electronic speed sensor in the trans, well like I said the '77/78's didn't electronic sensors they did not come out until 80 something. Kind of hard for an electronic sensor to work off a plastic drive gear. I've got the correct parts comming this afternoon and the external pulse generator comming on Monday.
Thanks
Old 01-23-2009, 09:55 AM
New Member
You should be good-to-go
Have fun
Mark
SW speedo question 37fordpickup Electrical 2 12-19-2006 09:14 AM
TPI and 2.8 LITER ELECTRIC FUEL PUMPS WANTING INFO boneyard Buick Engine 0 03-18-2006 09:08 PM
TPI electric Fan HELP! boneyard Buick Engine 4 07-31-2005 12:21 PM
Mech to electric speedo alf1096 Engine 1 07-25-2005 06:36 AM
Speedo not working..4spd Trav Transmission - Rearend 5 07-31-2003 01:21 AM
