TPI horsepower - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-16-2005, 10:21 PM
TPI horsepower
I have A 305 tpi bored 30 over but everything else is stock as far as the guy that built it says . it does run well but would like to get more power from it? If anyone has swapped cams , heads, etc , any input would be helpful .
tmh
Old 07-17-2005, 05:55 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
A TPI engine will respond to the same mods as anything else. The difference is that you will need to have the ECU reprogrammed for the mods and probably larger injectors to handle the fuel needs.
Chris
Old 07-17-2005, 10:49 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
You can get better intake systems, Vortec spacer plates, headers, Hypertech programmer, and a catback system. None of these HP add ons will require injector or computer changes.
Old 07-17-2005, 01:50 PM
edge's Avatar
Time is short, are you ready?
Originally Posted by bracketeer
Vortec spacer plates, ... Hypertech programmer, ...None of these HP add ons will require injector or computer changes.
Vortec spacer plates on a stock TPI?
Hypertech programmer for an ODB-I ECM?
How much additional horsepower can the stock 19# injectors handle?
"Hypertech programmer" and not affect "computer changes"?
Other than a cold air intake system and free flowing exhaust system, a head and/or cam change will make the most power. Depending upon what you change to (i.e. size of the cam); yes, injectors and computer changes may be required. Another variable to consider is it a MAF or MAP (Speed-Density) TPI system? Ed
Old 07-17-2005, 05:18 PM
bracketeer's Avatar
489 Lemans
Vortec was a bad choice of words. It's called a Helix spacer. Gives better bottom end torque. The Hypertech programmer downloads the stock memory before changes are made. On a trick engine set up third party software would be needed.
Old 07-17-2005, 06:50 PM
TooSlow's Avatar
Beater Driver
Hopped up 305
Check out this site for some useful 305 buildup info:
http://www.ws6transam.org/
Old 07-17-2005, 07:42 PM
edge's Avatar
I was not aware that a throttle body spacer is available for the TPI system.
Also, as much reading and research that I have done on programming my TPI system, I never saw any thing offered by Hypertech for reading and programming an OBD-I TPI system. I would be interested in seeing these devices. Are you sure you haven't confused the Hypertech programmer for an OBD-II (LS1) and the original OBD-I (TPI)?
From everything I read at www.thirdgen.org, the only way to change an OBD-I system is to either erase the EPROM with a UV light, then load a new program using something like a PP2 (Pocket Programmer). Or, you can use a MEMCAL adapter to use a flash chip. Having a Hypertech programmer would certainly be easier and more convenient, but I have not seen such a device.
Could you give us some sources? Thanks, Ed.
Old 07-17-2005, 07:50 PM
bracketeer's Avatar
489 Lemans
Tpi
Power programmer 111 works on these vehicles;
GENERAL MOTORS
2004-05 GM 8.1 Allison 30022
2004-05 GM 4.3/4.8/5.3/6.0/8.1 4L60/4L80 30022
2001-05 GM 6.6L Duramax Turbo Diesel LB7 (2004 1/2 LLY) 30029
2003 GM 8.1 Allison 30019
2003 GM 4.3/4.8/5.3/6.0/8.1 4L60/4L80 30019
1999-04 Corvettes 5.7 LS1 All Trans 30025
2001-04 Corvettes Z06 LS6 Manual 30025
2002 GM 4.3/4.8/5.3/6.0/8.1 Trucks All Trans 30012
2002 Camaro/Firebird LS1 All Trans 30025
2002 Camaro/Firebird 3.8L All Trans 30009
1999-00 Camaro/Firebird LS1 All Trans 30025
2001 Sierra/Silverado 4.8/5.3/6.0L All Trans 30023
2001 Trucks & SUV's 8.1L All Trans 30023
1999-00 Sierra/Silverado 4.8/5.3/6.0L All Trans 30005
2000 Truck 4.3/5.0/5.7/7.4L All Trans 30024
1998-99 Truck 4.3/5.0/5.7/7.4L All Trans 30024
Old 07-17-2005, 08:17 PM
edge's Avatar
The last year for the Tuned Port Injection was 1992. The TPI was (is) an OBD-I system and in its stock form cannot be reprogrammed without a UV light applied to the EPROM or a flash chip conversion method. The flash chip method is the preferred method now.
Rather than explain this subject at length, please simply read this article - "Chips Know it All" and my tuning experience here
Below is a flash chip installed in a MEMCAL adapter. The MEMCAL holds the EPROM. The original EPROM is bypassed and the engine is run using the binary file contained on the flash chip. The second picture shows the assembly installed in a 1990-1992 Corvette #727 ECM.
Neither method permits the simple downloading and reprogramming of the stock MEMCAL (EPROM). Now the OBD-II does have this option using a Hypertech programmer like mentioned. But his question was specific to a TPI (Tuned Port Injection) system which is an OBD-I system.
Ed
Old 07-17-2005, 10:18 PM
97Z28's Avatar
NTI Grad.
umm... yeah. you can get a throttle body spacer for anything with a TB. from TPI to TBI to SFI to MPFI... as long as it had a throttle body your good to go. bit they make carb spacers for carbs as well.
Old 07-17-2005, 11:32 PM
Siggy_Freud's Avatar
They do make TB spacers but keep in mind you'll have to lengthen your throttle and detent cables for it to work. Many better upgrades before doing the spacer IMO.
Hypertech makes no programmer for the TPI systems. They make no programmer that I am aware of for the OBD-1 systems. Flash memory like your talking about wasn't standardly introduced until the OBD2's in 1995 (at least that I am aware of).
Bringing history and technology together.
Old 07-18-2005, 09:53 AM
97Z28's Avatar
NTI Grad.
all the TB spacers that i've worked with have special brackets in the kit to relocate the throttle and kickdown cables. standard feature
Old 07-18-2005, 10:02 AM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
i dont care for this guy's chili recipe!
( http://www.ws6transam.org/chile.html )
Old 10-04-2005, 12:59 AM
TPI on 5.3
Can a TPI system be installed on a 5.3? If so any major modifications?
Thanks -Nolan
Old 10-04-2005, 01:22 AM
You would have to get a manifold that would fit. The 5.3's have Vortec heads dont they? You probably wouldn't have to play with the chip settings much as the displacement is rougly the same. I imagine the cam specs on those engines are somewhat close to stock TPI settings as well.
Build for Hp or Torque? Venturat Engine 76 09-23-2008 10:22 AM
TPI Q's: jesse01 Engine 10 02-20-2005 08:37 PM
tpi system on a non tpi setup Siggy_Freud Engine 2 02-18-2005 10:05 PM
tpi setup, opions Blob Engine 0 02-15-2004 08:32 PM
what exactly is horsepower ewibolo Engine 7 03-05-2003 09:39 AM
