TPI Intake on TBI heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-26-2004, 05:29 PM
NAIRB's Avatar
Do you guys know if the Tuned Port Injection manifolds have angled center bolts like the TBI cylinder heads, and are they a direct bolt on. I've got a guy who wants to buy a special set of torque heads I've built and he's asking me if a TPI will bolt on. I don't have any tuned port set ups laying around, so I can't give him an answer.
Old 11-26-2004, 06:09 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Could be wrong on this, but I believe it depends on the year. I think that 85-86 would not work, but 87-? might. Siggy_Freud seems to be studied up on this stuff and would probably know for sure.
Chris
Old 11-26-2004, 06:12 PM
NAIRB's Avatar
The TPI system the guy has is off of an 87 Corvette if that will help any.
Old 11-26-2004, 07:20 PM
guba_unus's Avatar
Learning from your mistakes
Last journal entry: CS-144 alternator
The heads are the same as any other, pre-87 have angled bolts and 87-up have vertical center bolt/studs. So the manifolds follow likewise. His lower manifold would have to be drilled out to fit onto your heads.
I went through this when I was looking at setting up a TPI system on my block, had to hunt down a pre-87 TPI unit so that the bolts would fit. Try this site, lots of working knowledge about TPI: http://www.thirdgen.org/techbb2/
whole section dedicated to TPI in the tech boards section, about 1/4 page down.
Old 11-26-2004, 08:54 PM
NAIRB's Avatar
If that's the case, his manifold should fit since it's an 87 model TPI. I would have to think that it should have the center bolts that are at a different angle from the outer four bolts just like any TBI head would be. It's no big deal, because I can redrill the head if need be, but I would like to know what I'm dealing with here.
Old 11-26-2004, 11:32 PM
GMC boogie's Avatar
Im pretty sure the corvette L98 TPI had the aluminum heads which have the old standard intake bolt angles. The TBI heads have the more vertical center intake bolt angles.
