TPI Lines - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2010, 04:23 PM
Mobileortho
TPI Lines
I'm making the switch from a carb back to fuel injection and having a hard time locating the steel lines that attach to the fuel rail. I know that brake lines with stands some pretty high pressures. That being so, can I use say a 3/8th brake line as a substitute?
Old 09-01-2010, 07:36 PM
LATECH's Avatar
Absolutley. double wall steel line like brake line is perfect. Just remember to make the jump from the body to the engine point with some hose so it flexes with engine movement. You can use regualer Fuel Injection hose and then flare the end and put flare to hose barb adapters on it. use a fuel injection style clamp with a real nut and bolt not screw clamps like a radiator or carb fuel line clamp . Oetecker clamps are ok if you have the tool.
I would surf the U pull it yard first if at all possible. Maybe there is one setting there waiting for you
What to do with old a/c lines jjupiter100 Engine 1 01-01-2010 07:00 PM
Bad rubber fuel lines ScoTFrenzel Hotrodding Basics 4 01-06-2009 02:48 PM
Brake Lines for 1968 Chevy SWB 68chevytrkr Suspension - Brakes - Steering 2 10-03-2006 02:34 PM
tpi system on a non tpi setup Siggy_Freud Engine 2 02-18-2005 10:05 PM
Kerry and jobs overseas... lluciano77 Hotrodders' Lounge 9 12-25-2004 08:59 PM
