Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - TPI on older motor??
Old 03-30-2002, 06:00 AM
Rick Holden Rick Holden is offline
Sounds like a neat combination. jprowse00 and kiwiconnection are both on the right track with advice; as far as the knock sensor, your block will have a drain plug in both sides of it; that is where the knock sensor is screwed into for smallblock chevys (teflon sealer and torqued to 15 lbs ft).
