TPI Programming with wrong sized injectors referenced. - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-02-2008, 07:53 PM
Last journal entry: Oil Leaks and Nobody said look for ...
Hi Hotrodders,
I ordered a programming service for my TPI system. My TPI system is off a 305 but the engine is a 355. I told the programmer that I was using 24 lbs. injectors but I discovered that I am actually using 22 lbs. injectors. How big of a deal is this error? I am using an adjustable fuel pressure regulator. Can I use the fuel pressue regulator to compensate for my programming error? Or is it a non-issue?
Thanks in Advance,
ericbr
Old 01-02-2008, 08:50 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
I have yet to use one of these programmer's. Is it re-writable? It will effect the on-time of the injector referenced to the pressure given not available pressure. By doing so in your case it will keep the on-time shorter for a 24psi pressure given injector, leaning out your injection. This will be the same regardless of the mechanical pressure you have.
Old 01-02-2008, 08:52 PM
Had to rewrite the post as I read your post backwards. Short answer, I don't think you'll have an problems. I suspect the tune will be slightly rich as delivered, based on what I have seen on chips in the past.
Old 01-03-2008, 12:25 PM
Originally Posted by ericbr
Hi Hotrodders,
Thanks in Advance,
ericbr
Probably a non issue, but yes, you can tune this with the pressure regulator.
Bogie
Old 01-04-2008, 04:13 PM
Siggy_Freud's Avatar
If anything, I imagine you'll want to turn the fuel pressure up a bit. If the computer thinks you have 24lb injectors, it will fire them for a shorter period than if you had 22lb injectors. By increasing the pressure slightly, you'll pump in more fuel during that shorter fire (duty) cycle.
This is all assuming the tune is pretty spot on. Like was mentioned, tunes tend to come rich, as the problems/symptoms with a rich tune tend to be less noticable and damaging than a lean tune.
What type of programming setup did you go with?
Bringing history and technology together.
Old 01-07-2008, 10:49 AM
What type of programming did I go with?
I am using a piggy back approach. I use the stock GM PROM with the prepared chip sandwiched between the stock PROM and the computer. The programmer than puts my specs into this adapter piece.
I pretty much went with the stock specs except fan temps on-195, off 180. I am using the EGR but not the air pump, redline 5800, speed limit 155, using cold start, no VATS, and injectors 24-lbs.
Thanks for your interest and reply,
ericbr
Old 01-07-2008, 02:33 PM
The stock PROM is kept because it retains the "Limp home mode". If something goes wrong and it kicks and engine light, the computer jumps over to the stock chip for safety mode. I am very familiar with this setup. I imagine your chip is a flash burned chip too, instead of a UV chip (as most UV setups dont require an adapter).
TBI Injectors vs TPI Injectors Junorr Electrical 3 09-02-2004 10:35 PM
