TPI / speed sensor - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2008, 01:10 PM
Mobileortho
TPI / speed signal sender
I'm in the process of wiring my truck. I added a 327 and swapped the carb for TPI. I also installed a set of bedee 5" guages. I hooked up the speed sensor (3 wires, black, red, & white) over the weekend but noticed that the TPI harness has a two wire hookup(grey & yellow I think) thats supposed to be spliced into the speed sensor. Can anyone tell me which wire goes where?
Old 08-07-2008, 05:59 AM
This question doesn't make sense. What are you calling a speed sensor? The speed sensor on the trans? The air/mass/density sensor in the intake? What kind of a truck? Is the TPI an aftermarket or a factory TPI? If factory did you change the whole harness, PCM and all? If aftermarket you should have a wiring diagram.
Old 08-07-2008, 06:59 AM
Mobileortho
Sorry for not being more specific. I meant the speed signal sender that attaches to the 700r4. I have a 327 that I added TPI in a '50 Chevy 3600. the harness has two wires marked for the signal sender but I don't know which wire goes where.
Old 08-07-2008, 07:17 AM
The speed sensor should only have 2 wires coming out of it. Are you sure you have the correct sensor? It should be in the trans tailshaft on the left side. What did the trans come out of?
Old 08-07-2008, 08:21 AM
Mobileortho
Yep, three wires. It came with the guages.
Old 08-07-2008, 11:49 AM
So the speed sensor is an aftermarket sensor that came with the gauges? They should be able to tell you how to wire it. I thought we were talking about an OEM style speed sensor. Sorry I can't really help you.
tpi??? jkingof9561 Engine 32 06-08-2008 07:48 AM
Speed sensor question biggeazy-e Transmission - Rearend 16 05-19-2007 09:59 PM
GM Vehicle Speed Sensor question (swap) biggeazy-e Electrical 3 05-01-2007 06:47 AM
TPI hot rod questions radracer43 Engine 1 09-11-2005 11:20 PM
O2 sensor crshrmn3 Engine 2 09-01-2003 02:12 AM
