TPI-Tech gauges - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2004, 03:47 PM
TPI-Tech gauges
Greetings!
I am still debating which gauges to install in my 69 El Camino. There are a few options: one to go with the digital ones (nordskog, for ex.), the other is to stay with the classical look.
Has anyone had any experience with TPI-Tech gauges? I found some for a good price and am wondering quality wise if they are worth the investment.
Also, the fuel sender which comes with the kit, has a 240-33 Ohm setting. Are there different resistors for GM fuel tanks to replace the Elky 0-90 Ohm one?
Thanks,
Denis
'67 Camaro RS
'69 El Camino - project in progress
Old 11-07-2010, 04:53 PM
TPI-Tech Gauges
Denis, I have a set of the white gauges and love the look. BUT, I have spent a month and a half trying to get the speedometer programmed. Still not there. All other gauges work fine.
I have never had a problem getting through to Rick in tech support and he has given me a lot of different things to try, just none have worked. It is probable something that I have done wrong in the wiring, but can't find out what that may be.
Joe
Old 11-08-2010, 09:19 AM
Hi Joe,
I appreciate your response. Unfortunately it was back in 2004 and a lot of things happened since then :-) I sold my El Camino to focus more on my 67 Camaro project. I ended up getting Autometer gauges - the fuel gauge Ohm settings matched perfectly my 67 fuel tank. I have had Autometers for over 6 years now and every gauge works.
Regards!
Denis
Old 11-08-2010, 10:30 AM
dinger's Avatar
i have the electric gauges in my coupe, the "quads", I believe they call them, 2-4in gauges. I like them a lot, but I am having issues with the temp gauge, I bought a new sending unit, factory, still a no go, I may have to order a sending unit from TPI. If there is an alternative, let me know please.
I used a GPS to set the speedo, works great! The tech department is one of the finest I have dealt with, if no one knows the answer to my dilemma I will call them.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
