TPI throttle body vacuum hookup - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2011, 06:52 PM
I have a SBC with Holley Stealth Ram TPI system and I don't believe previous owner has vacuum lines hooked up correctly for PCV. Does anyone know where I can find instructions indicating which ports on the throttle body go where? The PCV is currently connected to a port with no vacuum at idle. There's another port below that one which has a lot of vaccum at idle, but I'm not sure if it would be too much for the PCV. Any help would be appreciated.
Old 07-10-2011, 11:02 PM
On the stock tpi the pcv went from driver side valve cover to a port between the runners in that side and the top port on the tb was the "breather" connected to the pass side valve cover.
On my super ram setup I use the bottom port on the pass side of the tb to pcv and top port as the breather on the other valve cover
Old 07-10-2011, 11:03 PM
bigdog7373's Avatar
Of course it's fast
Pcv should have full time vaccum.
Old 07-11-2011, 12:33 PM
Check out this site.
http://chevythunder.com/
Vacuum Hookup problems on a 1967 289 jsm1847 Engine 7 03-31-2011 10:26 AM
Vacuum modulator hookup for automatic 65malibuSS Transmission - Rearend 2 11-29-2010 10:27 AM
Vacuum and Intake/Throttle body Question. elcrusch1 Engine 4 10-06-2006 09:36 AM
Jeep 2.5L throttle body to 4L throttle body. Parisienne66 Engine 2 07-10-2005 08:35 PM
distributor vacuum hookup highway star Hotrodding Basics 6 06-16-2005 06:15 PM
