Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - TPI with Turbo
Thread: TPI with Turbo
Old 03-18-2010, 07:09 AM
ap72 ap72 is offline
Banned
If you're going to run the stock TPI system there is no need for 180cc runners, your intake will be the choke point with any decent set of stock heads. YOu're going to want to use forged pistons, DO NOT use a reground hydraulic roller, when you grind it it looses the surface hardness, Vortec engines never had forged cranks, coil on plug at this level is a wasted expense, but if it floats your boat...
The intake is your biggest restriction.
