Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - TPI with Turbo
Thread: TPI with Turbo
Old 03-18-2010, 08:30 AM
ap72 ap72 is offline
Banned
it depends what you want. the thunderbird turbos will be all done by 5000 RPM, BUT they will spool fast.
I'm kind of getting the feeling you have champagne tastes and a chocolate milk budget though...
A good custom cam is going to be required to get whatever random mix of swap meet parts you pick up to work together. Any used turbo is not going to be optimal for your setup, just do the best you can though and since your power levels are fairly modest you should be able to make it. Don't cheap out on injectors, a starved turbo engine is a BAD thing.
