TPI with Turbo - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-18-2010, 11:52 AM
I'm from south texas and 300zx turbos are always at our local u-pull-it. But they are kind of tough to get out. sorry, way too busy right now to be pulling off turbos.
later 300zx turbos came with twin T28's (you can't use these).
the first generation 300zx turbo were 3 liter single turbo setups. this is the one you should use. Of course, you will require a turbo from 2 different cars.
a 280zxt turbo will also work. 168 cid and one single turbo. It is also a T3. But these turbos use the 180 degree thrust bearing (non-water cooled center section) and should only be used to 10 to 12 psi of boost.
  #17 (permalink)
Old 03-20-2010, 08:44 AM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
alright ill keep looking around. what would be the power difference between the tpi intake vs an lt1 intake or maybe an aftermarket like holley stealth ran or the edelbrock pro flo xt?
  #18 (permalink)
Old 03-21-2010, 07:39 PM
Listen and Learn
Wiki Edits: 7
Whats involved in converting an LT1 intake to be used on a gen I sbc with the standard bolt angles. Also what is the difference between the lt1 and the lt4? Thanks
  #19 (permalink)
Old 03-22-2010, 07:30 AM
think of a turbo as a power multiplier. the more you start off with, the more you will end up with.
tpi start up at 245, lt1 start at 300. then 7.5 psi of boost will add 50% more power (hp and torque).
if you have a tpi then use it.
if you don't have an engine yet then go for a late model 5.3.
  #20 (permalink)
Old 08-31-2012, 04:35 PM
twin turbos to Tpi
How is your project going?
I have used 2 Mitsubishi 13t turbos from Volvo 940 at my 305 -87. It works ok.
Tpi twin turbo TpiRegal Engine 19 11-23-2014 04:37 PM
78F150 shortbed 4by-granny 4 speed,300six & 301 turbo jtyler Engine 27 08-25-2007 07:31 AM
modifying a fwd cars strut tower for turbo clearnce - advice needed lowROLLERchevy General Rodding Tech 4 03-10-2006 11:20 PM
turbo 350 on a TPI motor?? punk1c5040 Transmission - Rearend 2 01-11-2006 09:19 PM
88 Corvette TPI with Turbo 400? wayja Engine 1 04-11-2003 04:13 PM
