TPMS- tire pressure sensors - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-16-2012, 11:50 AM
kleen56's Avatar
OK, I just purchased some new rims and tires and mounted them on my car. Now the tire sensor light comes on. The new rims don't have the TPMS sensors installed. Any suggestions on how to make this light go off, otherthan removing my old sensors and re-installing them on the new rims? Another set of sensors is $200 and to dismount the tires and install the sensors is another $100. I paid less for the rims/ tires (they were used) Can you say "what a rip off...."
Old 04-16-2012, 04:26 PM
T-bucket23's Avatar
Wiki Edits: 26
There is no way around them. I guess you might be able to pull the bulb if it has one. A lot of the newer dash boards don't use individual bulbs anymore.
If you could figure a way to lock the sensors on you could just throw them in the glove box.
Chet
Old 04-16-2012, 06:06 PM
kleen56's Avatar
I did some research on other sites and these are suggestions they had to fix the problem. They took the old sensors out of the original rims. Then purchase a 3" PVC pipe and two end caps. Drill a hole in the pipe and mount a standard type schrader tire valve into the pipe. Then place all four sensors into the tube and glue the caps on both ends. Once it's set, put 35lbs of air pressure using the tire valve you mounted on the pipe. The TPMS will read the sensors and air pressure via radio waves and the light turns off. Simply put the tube in the trunk or near the spare tire. I've also seen people buy a wheel barrel wheel, take the tire off and place the sensors inside the wheel. Inflate to 35 lbs. and same results.
Old 04-16-2012, 06:10 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
we run two sets of tires (snow and summer) on most of my cars
and use the sensors in only one set
so when they are not being used
I just ignore the light or put a small sticker over
Low tire pressure grapro Electrical 2 11-14-2007 05:03 PM
Tire Pressure for Slicks juiced66malibu General Rodding Tech 1 09-28-2005 03:56 AM
Tire Pressure 68firebirdguy General Rodding Tech 14 07-21-2004 09:16 PM
Recommened Tire Pressure? Malibucdl General Rodding Tech 10 01-12-2004 11:06 AM
Proper Tire Pressure ?? bigjoedo Suspension - Brakes - Steering 2 06-24-2002 03:08 PM
