tps sensor wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2010, 07:58 PM
The mobile view is crap
tps sensor wiring
I have a Holley TBI for a Chevrolet. I have a 1993 Chevrolet K1500. The Holley tbi has the older throttle position sensor on it. The truck has the round plug with three wires and the throttle body has the flat plug with three wires. Can I cut off the connector on the truck and wire the older style plug on and the tps work correctly. Both sensor plugs have the same three different colored wires, so would I just wire up the wires to the same colors.
Also the Holley tbi doesn't have the idle air control or even the provisions for an idle air control valve. What would be the consequences for not having the idle air control valve?
Old 02-08-2010, 10:12 PM
406cu.in. of tire smokin' fun
Last journal entry: 406 Build Thread
I had the same thing on my truck. It worked just fine wiring in the other connector. Mine was the older TBI going on my '91, but it had an IAC. I haven't seen them without an IAC before. If it isn't there, you'll get a check engine light. I also don't see how it would idle if you can't control the air needed to make it idle.
If you're putting that TBI on, you'd better be prepared to burn chips because it will blow black smoke otherwise. Also, if you have the old style injectors (with the dome cap) you may want to change them as they are not very good.
Old 02-08-2010, 10:33 PM
I have 2 kits both don't have a isc,so I was wondering about this myself.No instructions in kits.
Old 02-08-2010, 10:36 PM
What kit numbers do you guys have?
Old 02-08-2010, 10:46 PM
Box has the number 502-20s
Old 02-08-2010, 11:01 PM
Oh, that's the pro-jection system. I had the TBI system, so I'm afraid I can't be much help there. If you go to http://holley.com/TechService/Instructions.asp any type in your model number, they have instructions.
Old 02-09-2010, 12:09 AM
It is a tbi.
Old 02-09-2010, 08:22 AM
I mean their "replacement" TBI. The pro-jection is a whole system if I'm not mistaken.
Old 02-09-2010, 09:18 AM
Correct. Just to be clear, Holley made direct replacement units for GM TBI factory systems, and the Pro-jection system as a stand-alone unit. The Pro-jection throttle body can be made to work with the GM computer, but as noted, expect to burn custom chips.
Old 02-10-2010, 07:03 PM
I am running the Edelbrock Multi-Point conversion kit so the throttle body is just being used as an air valve. I am concerned with the idle air control. Will the truck just idle rough or will it idle at all. If I just plug the sensor in and tie it to the intake will I still get the check engine light?
Old 02-10-2010, 07:07 PM
Did you get any instructions with it? There's got to be a way around it. It could be as simple as an idle adjustment screw, but spending all that money on a port fuel injection kit tells me there should be more. Like I said though, I don't have any experience with it, just TBI.
This is a good forum, so I'm sure someone will chime in.
Old 02-10-2010, 07:45 PM
I bought the throttle body on ebay. I paid 30 bucks for the damned thing because the guy said that he could not get the injectors to work. I couldn't either. But I bought it because I thought it would work good with the multi point to get more air in the engine. I didn't even consider it not having the idle air control.
Old 02-16-2010, 08:45 AM
IAC primary purpose is to keep the idle RPM constant when going from Park or Neutral to Reverse/Drive and when the air conditioner is turned on. Other words, it keeps the idle RPM constant. You don't need it if you can live with the slightly higher than normal idle RPM while in park and neutral. You are going to either be lucky or good, or both, if you get that mix-mash set up to work!!!
Trees
Old 02-16-2010, 02:18 PM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
The Pro-Juction throttle body actually has the IAC boss in it, it just isn't drilled. I bet it could be retrofitted by somebody crafty, I've got one here I've thought about trying it on, if I EVER get any spare time to tinker,
How do I install a TPS in a 91 350 Blazer slyshar2 Engine 2 06-27-2006 11:54 AM
Adjustment tool for TPS screw sabino56 Engine 1 11-27-2005 07:11 PM
TPS sensor and Converter question. Parisienne66 Engine 5 05-12-2005 11:50 PM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 01:48 PM
Adjusting my TPS? 5.0Towncar Engine 18 04-04-2003 08:53 PM
