Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - tq issues with ultra bell
Old 04-29-2012, 10:37 AM
nskeeter99 nskeeter99 is offline
I snapped my bell housing on my 700. So i figured i would just up grad to the ultra bell. when i bolt it up to the motor, the tq is too tight. If i line it up with the raised bolt holes in the flywheel its super tight and you cant move it. If i line it up beside the holes with some effort you can move it. I don't have to back off the bolts much at all to get it to move. my tq is set in the pump. Am i stuck getting a new tq, are can i grind my mounts down a Little?. Maybe even cut the pump eats down a Little more.
