tq issues with ultra bell
I snapped my bell housing on my 700. So i figured i would just up grad to the ultra bell. when i bolt it up to the motor, the tq is too tight. If i line it up with the raised bolt holes in the flywheel its super tight and you cant move it. If i line it up beside the holes with some effort you can move it. I don't have to back off the bolts much at all to get it to move. my tq is set in the pump. Am i stuck getting a new tq, are can i grind my mounts down a Little?. Maybe even cut the pump eats down a Little more.
I know you said it was, but it sure sounds like the converter is not fully engaged into the pump, and I hope you didn't force things too much as the pump can easily be ruined by doing so. First thing I'd do is go to a tranny shop and get a measurement from a stock 700, pump face to outer edge of the bell. Then compare that to your Ultra Bell and see if they're the same.
Russ |
| All times are GMT -6. The time now is 07:30 PM. |
