tq issues with ultra bell - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2012, 10:37 AM
I snapped my bell housing on my 700. So i figured i would just up grad to the ultra bell. when i bolt it up to the motor, the tq is too tight. If i line it up with the raised bolt holes in the flywheel its super tight and you cant move it. If i line it up beside the holes with some effort you can move it. I don't have to back off the bolts much at all to get it to move. my tq is set in the pump. Am i stuck getting a new tq, are can i grind my mounts down a Little?. Maybe even cut the pump eats down a Little more.
Old 04-30-2012, 07:47 AM
S10xGN's Avatar
Gotta love a turbo!
I know you said it was, but it sure sounds like the converter is not fully engaged into the pump, and I hope you didn't force things too much as the pump can easily be ruined by doing so. First thing I'd do is go to a tranny shop and get a measurement from a stock 700, pump face to outer edge of the bell. Then compare that to your Ultra Bell and see if they're the same.
Russ
ultra bell with stock converter nskeeter99 Transmission - Rearend 1 03-31-2012 02:38 PM
Ultra leather 1bad32 Interior 8 10-12-2011 08:01 PM
Dodge poly bell housing; what manual transmissions fit the bell housing? Hemi-Meadowbrook Transmission - Rearend 2 03-08-2011 08:07 PM
ultra bell housing slik Transmission - Rearend 2 07-31-2004 06:37 PM
ultra coil vanashae Engine 0 01-12-2003 06:54 AM
