-   Modern Electronic Engines (http://www.hotrodders.com/forum/modern-electronic-engines/)
-   -   TQ and power curves LSx engines (http://www.hotrodders.com/forum/tq-power-curves-lsx-engines-225763.html)
1Gary 11-05-2012 10:35 AM
Honestly if in knowledge I am weak in it is the LSx engines.I am trying to research that as fast as I can to shore up that.At 65 yrs old I have spent my entire life in first gen Chevy's.
But for now the primary question I have is how does the LSx engines compare to like a 383 in TQ and power curves??. With the 383's you can build tons of TQ right off idle.Does the LSx engines tend to come into their power curve later in the RPM range??. From what I have read the LSx's you can build alot of HP and get great gas mileage too.Kind of a cake and eat it too thing.The other thing I have read is the 6.0 is a gas hog.
I trust the input from here. It does seem to me there are a number of very knowledgeable engine builders.
Please and thank you in advance.
ap72 11-05-2012 12:41 PM
the LS engines are better in every single way when compared to a sbc. Better torque, better mileage, better power, better durability, everything.
1Gary 11-05-2012 02:30 PM
Maybe I would understand better if you could show me a example of the TQ curve for a LSx engine.
ap72 11-05-2012 03:58 PM
there are a lot of them on Google.com, just type in "ls dyno" or something of that nature.
1Gary 11-05-2012 05:26 PM
I looked at this as a source:
GM LS engine - Wikipedia, the free encyclopedia
Many have a TQ peak at 4,400.Hummm..........
1Gary 11-05-2012 06:25 PM
Yes I know this is early on looking into this.It does have me wondering if Chevy by design built these not to gave much output early on and that is the reason for the good gas mileage.
ap72 11-06-2012 07:40 AM
you have that entirely backwards. They have GREAT low end out put and that goes along with good gas mileage. I don't know how you could think they have poor low end.
Compare the 5.3l to one of the original 327's.
1Gary 11-06-2012 11:45 AM
I'm just looking at the 383 which by 2500 I'm well into the 4's in TQ and from the Wiki link I don't see that.In you honest opinion what is the single thing Chevy did to make these so much better?? Compression with aluminum heads in used. Try to remember I'm still in the discovery stage on these LSx's and I am seeing some aftermarket parts for them that are priced reasonable and some that are not.
lmsport 11-06-2012 01:42 PM
Chevrolet Performance #19259233
LS376/525 Engine
376 cu in (6.2L)
525 HP at 6300 RPM
489 ft/lbs TQ at 4400 RPM
http://www.jegs.com/DynoChart/800/809/809-19259233.jpg
ap72 11-06-2012 04:42 PM
Here is a dyno of a fully decked out 383 GM crate engine.
http://www.chevroletperformance.com/...M_12370838.pdf
1Gary 11-07-2012 06:05 AM
My TQ build 383 was 400 lbs at 2500 and just shy of 500lbs at slightly over 4,000.It is 375 at 4500.
LS3 I would have to be very lucky to find a wrecked 2008 Vett will a willing seller that didn't want a fortune for it.It's kewl to pick out a engine here,but the reality check happens when you go for the wallet to pay for it.
The thing I do is I look at the aftermarket for problem solvers in the parts they offer to understand what might be a issue.One common part I see is head gaskets for these or to be fair about it some of the LSx engines.Is that a problem??. Also in the aftermarket blocks some of the features they offer to maybe cure OEM design weaknesses,but there again,that might be just because of the extra stress of power outputs that I would never approach.
I did read about the limits of the OEM head design/rockers for enough space under the rocker covers for a high lift cam.It seems a good set of heads would be in the range of $1,800 to $2,000.
But I an still curious what you guys think was the one thing GM improved on the LS engines that make them perform as they do.
johnnyg 11-07-2012 07:01 AM
My dad has an '08 GMC Savanna 3500 w/ a 6.0, on a good day he gets 14 mpg.
ap72 11-07-2012 07:47 AM
There are many things they improved, not just one. They improved heads, valvetrain, intake manifold, firing order, fuel and spark control, cooling, much more rigid block, better pistons and rings, etc.
If you're looking for just ONE thing then you'll never find it, the difference is because of many changes.
1Gary 11-07-2012 09:31 AM
That's what I heard while I have been investigating the LSx engines is the 6.0 are gas hogs.
ap72 11-07-2012 01:09 PM
I can't figure out what's wrong with my 6.0L then, i get 18mpg on a bad day, 22 on a good one.
