Track Roadster Wandering Problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2007, 08:52 PM
Good Evening,
I have built a track roadster that has a severe wandering problem. The front end is a spring over "I' beam with shackles and does not have a panhard bar. The steering box and associated linkages are tight. I understand someone makes a spring perch that gets rid of the shackle on one side (built to mount directly to the spring) and thus limits the side to side movement of the axle. Have you heard of this style perch and do you think it will "help" my problem. Any suggestions would be much appreciated.
A friend told me about your site and I am very impressed. Looking foward to helping and learning from my fellow rodders.
Thank you
Best Regards,
Pete
Old 01-08-2007, 09:05 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
A panhard bar should cure your problem....it did on my A model.
Old 01-08-2007, 09:37 PM
cucumber1949's Avatar
T-Bucket, Corvette, Mustang
Toe-out causes wander. I run mine at neutral toe - if I run it more toe-out, it starts to wander - if I run it too much toe-in it has occasionally suffered from mild shimmy. Also, a slight wander can sometimes be helped with more positive caster which can help the vehicle track straighter - I run mine at 4 degrees positive caster. As Henry suggests, a panhard bar will definitely help.
Old 01-08-2007, 09:43 PM
fenderlesspete
Just a couple of areas you may want to check:
1. if a steering box is not adjusted properly and to the proper spec. you could experience a wander. Make sure you adjust it on the "high point" and not too tight.
2. what are you running for tires? Speed rated tires can make for chronic nibbling problems, especially on roads where heavy trucks travel.
3. are the wheel bearing adjusted properly?
4. have you adjusted the toe setting?
5. how much is the caster set at?
IFS for 27 Track T Roadster Dave Carpenter Suspension - Brakes - Steering 16 01-15-2012 07:15 AM
89 Suburban 700R4 Problem JoeB Transmission - Rearend 13 11-06-2006 04:56 PM
Ignition Problem malibuman66 Electrical 17 01-24-2006 02:05 AM
1994 Saturn Transmision Problem dmg53 Transmission - Rearend 4 01-18-2006 07:59 PM
Track Roadster OneMoreTime Introduce Yourself 4 07-13-2004 11:46 PM
