track width measurement - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2004, 05:50 PM
streetrodder31's Avatar
Last journal entry: Final getting around to start back up
Question track width measurement
Hello all!
I have a quick question with my 53 chevy club coupe.
What is the track width measurement on the front of this car. my frame has no front end to it at all. I would like to know so that i can figure on what front suspension to use that comes close to it .
i have read about this but have had no luck finding the measurements. i have a shop manual for the car but it does not give any measurement. I hope any of you can help..
P.s. just a thought would any of you know around what donor cars could be used for a possible frame swap for this particular car. and what years would work. i know this has probable been asked before but when i try to look it up it takes me no where. so if you could help me. it would be grately appreaciated a lot. thanks.
Old 05-14-2004, 08:24 PM
astroracer's Avatar
Measure the rear track. It wouldn't be much different then the front...
I would suggest looking at a "G" body frame. Monte Carlo, Cutlass, Regal, Grand Prix from '81 to '87. It's going to be pretty close and there is a lot of performance parts available for the suspension and brakes.
Mark
Old 05-16-2004, 05:40 PM
measurements again
Thanks for the input astroracer, but one little prob. i have no rearend either. so i have no clue as to what the measurements are the frame i have. so here is what i have , i have just a frame no front crossmember assembly, no rear leafs or rear end just a clean slate, any ideas as to what to use for it, so i can get the thing on wheels, any input would be very helpful at this moment in time for me. thanks, i thought of a frame swap, but i keep getting different stuff from other builders, i need to know what i can use exactly i little resources around my area. repliys welcome. thanks bill taylor
Old 05-17-2004, 04:12 AM
astroracer's Avatar
Hey Bill,
The only recourse you have is to measure the width of the body from wheel well to wheel well. Measure from the inside lip. Once you have these numbers you can hit the junk yards and start measuring donor cars... I would think the "G" bodied cars are going to be your best bet though and doing a frame swap is a lot easier then trying to adapt suspensions and drivetrains to an older frame....
Good hunting
Mark
Old 05-17-2004, 06:07 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
Check the s10 they are real common.
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
