tracking - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2002, 04:34 AM
Post tracking
how is front/rear tracking measured. i ve looked on the "net" and cant find the info.
Old 05-04-2002, 06:59 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Post
Not sure what you are looking for here, so my answer might just fit my thinking on this. Wheel base is measured fron center of front wheel to center of rear wheel, this measurement is wheelbase. Track , the way I understand it is measured from center of tire tred left front to center of tire tred right front, this measurement will give you front track width. Rear track width is measured the same way only on the rear. Tire size(width) and wheel ofset or back spacing affects track width. For example reverse offset will widen track width and a wheel that is back spaced deep on the back side will narrow track width. This may not be what you are looking for as I could not understand by your question exactly what you mean't. Hope this helps.
