Tracking Down a Short - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-24-2009, 03:21 PM
hduff's Avatar
Fix it until it breaks
Last journal entry: Matt got a new motorcycle.
I've experienced a slow battery drain for a while and tracked it down by inserting a piezo buzzer between the positive terminal of the battery (which is located in the trunk) and the red battery cable. Then I pulled fuses to see where the short might be. I'm using a Ron Francis harness.
It turns out it's the #2 terminal of the AC/Delco 12SI 94 amp alternator. The alternator is wired: stud to starter via #8 wire and then to battery in trunk, can't remeber the guage, but it's one size bigger than the charts recommended; #1 to switched B+ in ignition circuit; #2 to bus that feeds the fuseblock for voltage sensing (I added this a while back because the battery is in the trunk and the BBC needs adequate voltage and current for the starter ).
Should I be hearing a tone (which means that current is flowing) at the #2 terminal?
Added: I did find this: "Another is that the field connection inside the alternator can allow a small current draw while the vehicle is not running, and this can cause a dead battery if the car is stored for a period of time." at Rowand.net
So do I have it wired wrong? The # 1 wire was wired per the RF instructions; I added the #2 wire for voltage sensing.
Old 10-30-2009, 04:01 AM
Pin number 2 does eventually go through a resistor network to ground inside the internal regulator, but per the attached doc, the drain is "negligible". I've found this doc to be a pretty good source on the different types. Image 010 looks like you describe your hookup.
http://oljeep.com/gw/alt/edge_Altern...html#Section_2
Old 10-30-2009, 05:34 AM
hduff's Avatar
Great link that was a big help. Thanks so much for the reply.
detonation resistance, short or long rods? Old School Nut Engine 34 12-31-2004 01:23 AM
Electrical Short Tool fourbyfourblazer Electrical 4 12-11-2004 09:01 PM
Diameter of SBC short water pump inlet ken47 Engine 1 11-25-2004 09:41 AM
tracking down a short - continuity cboy Electrical 5 11-19-2004 01:58 PM
Changing T350 short shaft to long shaft Jmark Transmission - Rearend 6 01-17-2004 05:22 PM
