Go here and check out the traction bars for the 53 chev pickup..those work quite well. Just use the peices that you have and make these..As far as the rear en holding...It depends on how hard you launch..
Sam
traction bar
Question 1: You want the snubber to hit directly on the underside of the front spring eye, that way bar and spring pivot around the same point. Hitting to the rear of the eye on the main leaf will just bend the leaf and make the bar less effective.
Question 2: I'd start with a 1/2" gap on both sides, then you can trim or shim the snubber as needed, and you may end up after track testing with gaps that are not equal from side to side in order to get the car to launch straight and even-- this is common. Question 3: Yes, weight must be on the suspension during set-up to ensure corrct fit. Question 4: You've got it figured right. Question 5: Depends on how hard you launch, are you using slicks? Street driving will slowly kill the aluminum spool by wallowing out the splines. I've done this several times with good results, the cheap bars were the easiest and cheapest ways to get the neccessary components. Last edited by ericnova72; 07-05-2007 at 04:15 PM. Reason: spelling |
| Roll Bar Install Advice | Mustangsaly | General Rodding Tech | 12 | 12-02-2007 08:33 AM |
| 1973 Mustang front sway bar question? | Steve-0321 | Suspension - Brakes - Steering | 1 | 12-11-2005 11:12 AM |
| no traction | roy383ci | Transmission - Rearend | 7 | 09-19-2005 02:47 PM |
| Questions, questions, questions? | slider in wa | Transmission - Rearend | 2 | 09-27-2003 02:01 PM |
| rear sway bar | DeathByGreaser | Transmission - Rearend | 2 | 02-07-2003 02:25 PM |
