Traction bars - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2003, 06:58 PM
nd500's Avatar
New Member
Post Traction bars
Anyone know if lakewood universal tracking bars are any good or should I just shell out the money for some competition enginering bars?
[ April 08, 2003: Message edited by: nd500 ]</p>
Old 04-08-2003, 08:25 PM
Skylark_77_455's Avatar
Post
Go with the comp engineering. The Kit is much stronger and keeps the rearend much more stable under load. The Lakewoods are bolton and if they hang under the spring, or wherever the snubber comes to rest on, then they would be useless.
Old 04-09-2003, 12:09 AM
mustang66maniac's Avatar
Ford Freak
Post
i dont know anyhting about comp. eng. bars but i have some SSM bars and they work great. It makes such a huge difference in traction. It makes the ride stiffer tho, but nothing that tortures you.
Old 04-09-2003, 05:06 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
Ditto on the SSM bars, but I would go with their lift bars. They are a bit pricey, but they are about the best traction upgrade you can make.
Chris
Old 04-09-2003, 06:01 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
I sent you a PM.
