Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Traction bars?
Thread: Traction bars?
Old 03-11-2010, 10:05 PM
NEW INTERIORS NEW INTERIORS is offline
life is a temporary assignment
Originally Posted by 383SBC
Hey guys got a question regarding traction bars. By installing a pair of these (in a camaro) does this replace the sway bar that runs behind the axle? Also does the traction bar bolt to the spring mount on the axle underneath the leafs and clamp to the leafs as well?
Thanks,
Keith
You can still run the sway bar.. And most do bolt to the bottom plate.. The clamp on the front, Is to help hold it in place when you let off the gas and hit the brakes.. Hope this helps..
