-   -   Traction bars? (http://www.hotrodders.com/forum/traction-bars-174351.html)
383SBC 03-11-2010 06:40 PM
Traction bars?
Hey guys got a question regarding traction bars. By installing a pair of these (in a camaro) does this replace the sway bar that runs behind the axle? Also does the traction bar bolt to the spring mount on the axle underneath the leafs and clamp to the leafs as well?
Thanks,
Keith
NEW INTERIORS 03-11-2010 09:05 PM
Thanks,
Keith
You can still run the sway bar.. And most do bolt to the bottom plate.. The clamp on the front, Is to help hold it in place when you let off the gas and hit the brakes.. ;) Hope this helps..
