Traction bars? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-11-2010, 06:40 PM
Traction bars?
Hey guys got a question regarding traction bars. By installing a pair of these (in a camaro) does this replace the sway bar that runs behind the axle? Also does the traction bar bolt to the spring mount on the axle underneath the leafs and clamp to the leafs as well?
Thanks,
Keith
Old 03-11-2010, 09:05 PM
NEW INTERIORS's Avatar
Set no limit's on yourself
Thanks,
Keith
You can still run the sway bar.. And most do bolt to the bottom plate.. The clamp on the front, Is to help hold it in place when you let off the gas and hit the brakes.. Hope this helps..
70 nova traction bars, leaf springs. HELP!!!! gilliganspl Suspension - Brakes - Steering 1 10-06-2009 02:52 AM
Air Shocks And Traction Bars?? tinman386 Suspension - Brakes - Steering 8 07-13-2007 09:09 PM
lift bars and traction bars hause Suspension - Brakes - Steering 1 10-05-2006 01:50 PM
Traction Bars or Ladder bars JamesRS Transmission - Rearend 1 07-19-2005 05:57 PM
traction bars corenele Suspension - Brakes - Steering 8 06-14-2003 01:37 PM
