traction bars, 67 Firebird, 71 rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-12-2005, 07:45 PM
red_rider52's Avatar
DriveItLikeItsSupostToBeD riven
Hello, I am looking into getting traction bars for my 67 Firebird. My problem is my rear end is out of a 71. Now do I need traction bars that will fit 67 or 71? or with either one work? Thanks
Old 05-12-2005, 08:01 PM
302 Z28's Avatar
Is that 71 Firebird rear end in the 67? If not, you will find that the 71 rear end is quite a bit wider than the 67.
Vince
Old 05-12-2005, 08:12 PM
I'm not sure what car it come out of. All I know is that its early 70s?? 8.5 10 bolt.
Old 05-13-2005, 03:23 PM
Hello, I just went under my car and I think my axle warp is worse than I thought, I seen that my Pinion yoke as been hitting the floor of my car . and the rubber bumper is also there.
Old 05-15-2005, 10:39 AM
any help??? I think I would have to go with traction bars for a 67 rear but i'm not 100% sure if they will work?
Old 05-15-2005, 12:04 PM
Dizturbed One's Avatar
you'll need to use second generation traction bars (something out of an early 70's firebird/camaro) if you're going to use that rear end, but you'll probably have to modify some 1st Generation endlinks to fit the bar.
I'm a Camaro guy too, I currently own a third gen. It's a 92 t-top.
check out www.camarosource.ca & www.thirdgen.org
both great sites with a plethora of knowledge pertaining to Camaro's along with great message boards and some knowledgable Camaro guys.
Old 05-15-2005, 12:30 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I grabbed this
Got it from Centerlines site..Build em this way There is a link to the chev pickup build that shows how to build some neat traction bars..
OMT
Old 05-15-2005, 08:35 PM
I seen the thread on her that centerline posted that shows you how to make those traction bars. I was thinking about making them but when I looked under my car to see if I would be able to I seen that there is no way I can bolt it to the front of the leaf spring there some sort of brace in the way . so I will just have to go with the regular traction bars.
Rear End Gunk? MrChevyDC3 Transmission - Rearend 2 02-19-2004 05:48 PM
69 Firebird Rear End pontiac69 Transmission - Rearend 8 11-30-2003 10:54 AM
rear end traction Junior's67 Suspension - Brakes - Steering 3 11-25-2003 09:23 PM
anyone running 700r4 with 3.55or 3.77 rear end? 37 chevy Transmission - Rearend 7 01-06-2003 06:34 AM
Rear end Buffed Engine 3 10-31-2002 05:11 AM
