Traction bars - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-12-2006, 09:36 AM
Last journal entry: Free tires
Traction bars
I've been seeing some round tube traction bars on some 1967-1969 Camaros and Firebirds. They have an adjustable rod end and are rigid mount instead of the typical slapper bars.
Any idea where to locate some?
They mount similarly like a ladder bar but are a little more forgiving in the ride quality it looks like.
Old 09-12-2006, 11:47 AM
Never mind, found them.
Took awhile but I found them at Jegs online. Looking up stuff online requires thinking in Yellow page jargon.
http://www.jegs.com/webapp/wcs/store...tegoryId=10083
Old 09-12-2006, 12:41 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Those are similar to the Cal Track bars but neither is rigid mounted in front, but rather pivot on the spring bolt to put pressure on the leaf spring.
Old 09-12-2006, 01:31 PM
Has anyone here run either of these type bars? Cal-Trac or Comp Eng?
What's your experience with them?
Old 09-12-2006, 02:56 PM
larryblack's Avatar
Certified Lead Foot
I personally have not used them, but everyone that I have seen with them says they work just fine.
I have not heard a discouraging word about them.
Old 09-13-2006, 10:27 AM
xntrik's Avatar
It all depends if you can stand the looks of all that stuff hanging down so low. They reduce ground clearance substantially. They work well for all out drag traction.
There are better ways to stop wheel hop and add traction on a street-strip car without the "looks.
www.readershotrods.com
Old 09-13-2006, 12:19 PM
Here's what I have now, clearence was never a real problem but I see what your saying.
I do like the ladder look but hate the ride, thought the slider link would offer a better ride and looks pretty good.
Before the ladders I had slappers. Those I had clearence issues with, so I do wonder about the slider link or Cal Trac since it mounts under the leaf spring which is why I'd like some user feedback.
ID:	14854   Click image for larger version
ID:	14855   Click image for larger version
Old 09-13-2006, 03:02 PM
xntrik's Avatar
The best feed back I can give you is to look at a car like yours with them installed. You will see that they hang down 4 inches below the front spring eye, about the same as a slapper bar. If the car is lowered, the bars will usually point UP towards the rear.
Read-up on Mopar Super Stock springs for other ideas.
Later model Camaros had the single "ladder bar" torque link that worked well.
Old 09-13-2006, 03:19 PM
72NOVA454
you mentioned "better ways" to stop wheel hop and add traction in the previous post. I have the same situation. Need traction control for my 72 nova with leaf springs. Recomendations please..........
Old 09-13-2006, 04:56 PM
rj57's Avatar
I know the guys I talk with over on Chevy Talk say they love Cal-Tracs.
Some even home build their own versions for their cars.
A couple who run a store on ebay called: Oldedays, sell a cheaper version of Cal-Tracs.
Old 09-14-2006, 12:06 PM
xntrik's Avatar
see # 8
Look at the FatMan's trailing arm kit for the rear of the old Mustangs. This can be done with coil overs or quarter eliptical leaves.
Old 09-14-2006, 06:31 PM
Look at the 1st & 3rd pics 428ho posted. It looks like he's got the old Pontiac version of the same thing, 3 leaves back and 5 leaves front.
Old 09-15-2006, 01:12 PM
Found this in the Mopar search.
http://www.moparmusclemagazine.com/p...iant_traction/
Seems that by adding the Comp Eng bars they lowered the 60 ft times dramatically. From 2.84 to 1.88
Now that is a big difference for a bolt on part.
Old 09-15-2006, 03:29 PM
I made quite a few of these devices within the past year. They are similar to the Cal-trax device but have more adjustment. They actually improve your 60ft. times over the Cal-Trax. If you go to www.smithracecraft.com look up the Max-Trax. They work great and are very easy to install.
are these good traction bars for my 55 chevy??? tiresmoke55 Transmission - Rearend 4 05-01-2006 11:11 AM
Traction bars for 58 Chevy PU xxllmm4 Suspension - Brakes - Steering 2 02-21-2006 12:01 PM
Traction Bars or Ladder bars JamesRS Transmission - Rearend 1 07-19-2005 05:57 PM
traction bars, 67 Firebird, 71 rear end red_rider52 Suspension - Brakes - Steering 7 05-15-2005 08:35 PM
traction bars corenele Suspension - Brakes - Steering 8 06-14-2003 01:37 PM
