Traction help - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2011, 01:44 AM
Traction help
So I've completed a 383 in my heavy 65 Pontiac convert, the motor has exceeded what I wanted so far, full roller block, etec 200 heads, 9.7:1 comp, Duration @ .050'' 242° Intake/240° Exhaust, Lift @ Valve .594'' Intake/.594'' Exhaust, and so on..... Now I knew i was gonna have to do my rearend and gears, not sure of existing gears but super high. I was going to go with 4 11's and a posi but I'm a little worried that I won't be able to control this from a stop, basically I want to he able to launch but at present at any speed in 1st and most part in 2nd I just spin, would posi and a low gear or posi and same gearing be a better option? Just any input would help.
Old 07-11-2011, 02:13 AM
SSedan64's Avatar
To determine the Rear gear ratio;
Open Diff= Rotate 1 wheel 2 revolutions and count Driveshaft Revs.
Posi Diff= Rotate both wheels 1 revolution and count DS Revs.
A Posi will definetly help you traction.
What Diff does the 65 have? 12-Bolt, 10-Bolt?
Some of the large car rears have oddball sizes and can be very difficult to find performance parts for.
May apply if you have the Dropout 8.2" 10-bolt> http://www.bruneauperformance.ca/409...rendparts.html
Also boxing in the rear Control Arms or aftermarket Control Arms will improve traction.
Old 07-11-2011, 11:31 AM
It is a 12 bolt, I had done the rotation test months ago and came up with a number around 2.25 or so, I realize posi will greatly help, but I'm worried that 4.11's are so deep that it will be easily slipping,
Old 07-12-2011, 06:46 AM
SSedan64's Avatar
If you plan on much street use, something around 3.42 or 3.55 would work better to keep your cruising rpm down. For best performance your Cam will probably need 3.73-3.90 gears tho'.
I wouldn't go higher on the street unless you plan on swapping in an OD Trans such as a 2004R, 700R4, 80E etc...
With an OD Trans higher ratios such as 3.73 & higher gears work well.
An OD Tran's 4th gear will tame the higher ratios so you retain you cruise rpm & have good acceleration:
3.73 X .67 = 2.49
3.73 X .70 = 2.61
4.10 X .67 = 2.74
4.10 X .70 = 2.87
Trans Gear Ratios:
Trans--------1st-----2nd-----3rd------4th Gear-------------------------
TH350-------2.52----1.52----1.00--------------------------------------
TH400-------2.48----1.48----1.00--------------------------------------
TH200-4R----2.74----1.57----1.00-----0.67-----------------------------
TH700-R4----3.06----1.62----1.00-----0.70-----------------------------
4L80E--------2.43----1.49----1.00-----0.75-----------------------------
What Trans are you using now?
With a TH350 Trans and 2.25 rear Gears, running with the Trans in 2nd gear would be like having a 3.42 rear gear.
Old 07-12-2011, 01:25 PM
Great info, much appreciated
Need Traction Help xntrik Suspension - Brakes - Steering 3 02-04-2007 04:31 AM
traction bar ? runn141 Suspension - Brakes - Steering 3 12-30-2006 01:13 PM
no traction roy383ci Transmission - Rearend 7 09-19-2005 02:47 PM
No Traction brainsboy Transmission - Rearend 0 11-02-2004 12:50 PM
Traction where is it? Bullit 99 General Rodding Tech 1 08-26-2003 11:20 AM
