Traction Problems?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-15-2011, 12:32 PM
Traction Problems??
Hey Guys
I got a 40 Buick coupe with a 454 and th 400. The launch is limited by traction on the right rear tire. The rear setup is (I think) 80s vintage Camero with the Buick coils fitted to perches on the axle. It also has a torque arm running forward to the X crossmember and a Hotchkiss bar mounted to the axle on the right side and frame on the left side.
You would think that the weight transfer upon the "squat" would fall on the right wheel from the hotchkiss? It just seems that the right rear breaks loose easier than it should. I'm wondering if the hotchkiss is forcing the axle sideways as well as down? I'm thinking the sideways push flexes the tire wall and causes a decrease in traction through distortion in the tire tread. You can really feel the rear move sideways at the 1-2 shift of the auto. Any thoughts apreciated.
I guess the next big project will be to add a posi. I'm saving up. Thanks
Old 09-15-2011, 05:27 PM
sqzbox's Avatar
My pipes are my music
Trying to get a straight launch and traction with what you've got is like paddling a canoe on just one side! Get the posi!
traction problems? recnepswilliams General Rodding Tech 7 05-18-2011 07:36 PM
El Camino traction problems allenandannbeck1953 Transmission - Rearend 2 10-26-2009 06:26 PM
traction problems lilrancoe42 Hotrodders' Lounge 8 02-18-2008 02:56 PM
Traction Problems brainsboy Suspension - Brakes - Steering 5 11-04-2004 05:47 AM
traction problems onebadmerc Suspension - Brakes - Steering 11 01-30-2003 04:00 PM
