Tractor fluid instead of regular tranny fluid! - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-11-2010, 10:32 PM
I recently researched using tractor transmission fluid in a turbo 350. I have some farm equipment and everything seems like it is very simular to regular automotive trans fluid other than it being clear it in color and a lot cheaper. I recently changed out the fluid in a turbo 350, it appears to work just fine in the transmission. I noticed the trans seems to be smoother shifting. Anyone else use this with good results? I used the Supertech brand, I buy it in 2 gal jugs. No problems yet. From what I have been reading it will work as long as it is rated for wet brake type machinery.
The Following User Says Thank You to Studebaker For This Useful Post:
revscott (09-21-2012)
Old 04-12-2010, 12:29 AM
Smoother shifting means it is slipping more when it shifts.
Time will tell.
Old 04-12-2010, 01:37 AM
ericnova72's Avatar
More for Less Racer
A lot of guys do this in a racing transmission, it raises the stall of the torque converter a few hundred rpm but doesn't seem to hurt anything. They usually add a quart or two of regular trans fluid just to give it some color so you can tell engine leaks from trans leaks and see the fluid on the dipstick.
Old 04-12-2010, 06:14 AM
Crosley's Avatar
Wiki Edits: 1659
If this tractor fluid is used on a street application , where the problems may arise is the lack of the proper additives for the control of moisture and other contaminants that build up over time
Old 04-12-2010, 06:36 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
First time I heard of this was from guys who "raced" Demo Derby. Some of these cars are pretty trick.
But like has been pointed out already, the additive package is sorely lacking.
Old 04-13-2010, 12:40 AM
Thanks for the reply, good information. I did not think of the moisture retention issue. Everything seems fine for now, I will keep monitoring it.
Old 04-14-2010, 07:01 PM
junior stocker's Avatar
I really thought it was just the opposite, that it LOWERS the stall slightly. I've heard it being used to "tighten up" a "too loose" converter. Adding something to tractor fluid to make leaks easier to locate makes good sense. Butch/junior stocker.
Old 04-14-2010, 07:36 PM
ericnova72's Avatar
More for Less Racer
You may be right and I may have it crossed up, I have never done it and only heard about it. Just seems like a poor idea to me anyway.
Old 04-14-2010, 10:06 PM
jakeshoe's Avatar
Lots of misinformation.
Tractor hyd/trans fluid is equivalent to Dexron. It actually cross references to Dexron when used in tractor applications.
It isn't a legal ATF for highway use because it isn't dyed red.
So it can't be sold for highway use.
It has a higher temp rating than Dexron.
If it had a "sorely lacking" additive package, I'm sure it wouldn't be OEM spec for warranty in a half a million dollar machine such as a combine or other heavy equipment.
It works well from our experience. There are two different common viscosities and it's better to use the thinner of the two.
Old 04-14-2010, 10:29 PM
Crosley's Avatar
Wiki Edits: 1659
good clarification Jake.
i was thinking of the tractor hydraulic fluid some race guys run , this would be the straight hydraulic oil
Old 04-14-2010, 10:56 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Mounts
I don't know. I think I'd be looking for PROOF that Hydra-Trans is DEXRON compatible.
Many things seem to "work just fine" when you first put them in.
For example, there's been more than a few farm boys around here that thought it would be a good idea to use ATF in their hydraulic jacks, too ... until they had seals go out on them.
I'd suggest that you buy your DEXRON in a 4L jug, or go to a petroleum bulk place with your own 5-gal pail or 50-gal drum ... but use DEXRON.
Old 04-15-2010, 12:40 AM
jakeshoe's Avatar
Here's your proof:
http://www.mobil.com/USA-English/Lub...lfluid_424.asp
Notice the print:
Suitable for commercial transmission applications requiring Type A (Suffix A), Dexron and Type F fluids. Do not use in passenger car automatic transmissions
COMMERCIAL applications since it is not DOT approved due to lack of red dye.
Notice the list of other tractor fluids that also cross reference at the bottom of the page.
1 minute on Google and you have proof.
I've done considerable research into the various fluids. There is nothing wrong with Dexron and it is my usual recommended fluid. However using a higher quality fluid (tractor hyd trans fluid in this case) that cross references will not cause any harm and in many cases has been proven to work better (extreme racing conditions).
In many commerical vehicles only one fluid is used in all the various assemblies. Engines, trans, axles, hubs, etc.
When you've poured the vehicle manufacturers OEM spec'd 15W-40 engine oil into an automatic transmission as many times as I have you won't worry about using a fluid that actually cross references to Dexron in one.
Old 04-15-2010, 05:19 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I was referring to the hardware store variety hydraulic fluid. My apologies for mistaking that for the "tractor transmission fluid" the OP was talking about.
The following was also provided in the link above:
"Suitable for commercial transmission applications requiring Type A (Suffix A), Dexron and Type F fluids. Do not use in passenger car automatic transmissions
"May be used in applications requiring API GL-4 or SAE 80W grade lubricants in all gear applications except hypoid gear designs
"Outstanding replacement for engine oils recommended for hydraulic and transmission systems"
Sounds like some tough stuff. I wonder how the cost compares to ATF. Does it being thicker affect the operation of a car tranny negatively in any way?
EDIT- Checking a couple sites, About $3/qt. when buying 5 gall. buckets ($58/5 gall).
Old 04-15-2010, 06:55 AM
counter point:
as far back as 2001 heavy duty tranny manufacturers bulletins have said do not use generic tractor hyd tranny oil "meets" spec labeled oils (which the Walmart oil is)...
http://www.allisontransmission.com/d...%20Rev%20E.pdf
heavy duty trannys operate with ALOT more qts of fluid than a car tranny so total contamination and breakdown % will take much longer...
so you saved a few bucks up front with tractor tranny oil but now your required fluid change interval has shortened...
(lab testing is too expensive)
race cars change fluids based on just short hours of use intervals when using tractor oil...
hey,,,
if it is a buy food for the kids or buy needed tranny fluid empty wallet condition (or a junk yard tranny to get you by),,,tractor tranny oil does work
lack of color dye is not why it says don't use in cars...
compare the physical properties chart of the Mobil 424 tractor tranny oil with this Mobil synthetic ATF...
http://www.mobil.com/USA-English/Lub...thetic_ATF.asp
just my $.02:
in the tranny is the one place synthetic oil operating properties are worth the extra bucks for long tranny life...
(especially in a hot rod build)
Old 04-15-2010, 12:02 PM
bobjob's Avatar
I've been a tractor mechanic for around 35 years now.. and in all of our overloaded service trucks we always used tractor fluids,, since we had a unlimited supply.. never had a problem.. and since we also pulled a trailer with a bobcat or welder ,,,box full of tools,, bunch of heavy parts .. we were WAY overloaded...BUT i cannot say that you using it in a car will be ok...I don't see that you can abuse your toy as much as we did on our service trucks though..
Fluid Won't Circulate REDSNAPPER Transmission - Rearend 2 04-14-2007 09:58 AM
Tranny puking fluid out DS tube Jmark Transmission - Rearend 5 04-13-2007 07:56 AM
B&M Transmssion fluid RAW Transmission - Rearend 6 01-04-2006 01:00 PM
Tranny fluid question McCutlass Transmission - Rearend 3 04-14-2004 08:52 PM
Tranny fluid heating up engine??? black66 Engine 1 07-13-2003 09:18 PM
