trading a 53 ford for a 67 mustang coupe - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2008, 10:00 AM
Hey, fella's need some advice, I have a 53 ford customline flatty, that is is taking up finances and time. I love it to death but also, have a ford f-100 I'm restoring. My question is a guy may want to trade his 67 289 mustang coupe for my flatty customline...waht would make it a good trade? If any?
Old 05-24-2008, 10:05 AM
Notorious's Avatar
Hot rodder, not street rodder!
If the Mustang was a fastback, I'd say go for it. But the coupes don't command anywhere near the price of the fastbacks. Myself, I'd rather have one nice '53 than 10 Mustang coupes. But hey, it's your choice.
Old 05-24-2008, 10:11 AM
I know for sure its a coupe...he said it needs some work as well...
Old 05-24-2008, 01:56 PM
72 grabber 51F-1 65 chevystang
If they were in similiar condition I wouldn't trade
Old 05-24-2008, 03:08 PM
Notorious's Avatar
The early Mustangs have pretty flimsy uni-bodies at best. They can look good on the outside but be falling apart underneath, structurally. I had a '69 like that, required all kinds of work to be safe and solid.
Old 05-24-2008, 03:45 PM
Really? so is there a way to check, without jacking it up? or can superficial rust help determine structural issues
Old 05-24-2008, 04:38 PM
Notorious's Avatar
If you can, take an experienced person with you. A good body man, a seasoned hot-rodder, etc. Anyone familiar with these cars will know what to look for.
Old 05-24-2008, 04:46 PM
will do, my brother is a body guy, he said the same thing...we're taking a compression tester as well. I'm just hav'en second thoughts about loosing my 53
Old 12-26-2009, 09:08 PM
ill take that 53 f100 off ur hands!
Old 12-27-2009, 12:14 AM
JeffB's Avatar
No Way! Jose
I would not do it no way,no how.I am sending you a pm hoping to help you thru this crisis
Old 12-27-2009, 02:32 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
I would keep the 53, much more unique than a 67 coupe.
Old 12-27-2009, 06:12 AM
Irelands child's Avatar
After owning both - I'd keep the '53. At least it has a real frame under it rather then that floppy sheet metal built up piece of junk that's under the front of the Mustang - and always needs replacement pieces. There is nothing but sheet metal body to the rear end - then more built up sheet metal assemblies. The only downfalls on the '53 are the kingpin 'A' frames and that weak tranny/differential that even a flattie can destroy with ease. It has an engine bay that will hold most any modern OHV engine - and I used mine for a test bed for many of them - after changing to an 8" diff. The Mustang - tight with those shock towers for much of anything larger then the OEM 260-302 size motor. The one nice part of the Mustang - you can buy every part that's bad or missing, tho fairly expensive.
Dave W
Irelands child
Old 12-27-2009, 08:18 AM
wretched ratchet's Avatar
one full turn after it squeeks
When I first saw this post, I figured I would be in the minority but I can see that my views are pretty much the same as these others who have commented so when it comes to making the trade I say "Bad Move" !
Old 12-28-2009, 11:30 AM
You'll be the owner, so own what you like. But as said, Mustangs rust from the inside out. Any unibody is the same, Camaros too. They can look clean on the outside and be ready to buckle in half. Know what you're looking at. Best to take along someone who has done a Mustang or Camaro before if you can. He will know exactly where to look. Inner rockers, floor pans, torque boxes, rear quarters and rear wheel houses, trunk floor, front and rear frame rails and more all can be bad. Lift up the carpets and look at the floorpans if he'll let you.
Old 12-28-2009, 07:16 PM
life is a temporary assignment
Keep the 53.. You will be much happier in the long run...
41 ford coupe fabricator Hotrodding Basics 13 04-05-2015 08:32 AM
List all of your cars HERE! Carbed95GT Hotrodders' Lounge 289 11-09-2011 06:43 PM
Using 84 Mustang Frontend under 51 Ford Tudor bigbrowndog General Rodding Tech 1 09-18-2006 08:36 AM
Suspension options for 41 ford coupe Thunder Road Suspension - Brakes - Steering 1 09-15-2006 05:22 AM
351M in a 54 Ford Pick up with A TCI Mustang crossmember baylow1 Introduce Yourself 1 08-03-2005 09:06 PM
