trailer brake controller = PWM? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-07-2011, 01:02 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Does a trailer brake controller modulate brakes using a PWM signal? Or is it potentiated/resistor?
The reason I ask: I've been considering a home-brew manually variable assist steering based on a Cadillac PS pump/PWM valve, but I need a way to operate the PWM valve on the pump. I was thinking a trailer brake controller... but only if they are PWM.
Old 02-07-2011, 05:57 PM
LATECH's Avatar
If you have a modis with a scope you should be able to find out that way , I think some are pulse width modulated,not sure.Like I said put one on the scope.
Old 02-07-2011, 08:17 PM
curtis73's Avatar
Wiki Edits: 16
I'll see if I can find a suitable scope. I'm still trying to find the right diagrams and descriptions to see what type of pulsewidth and modulation the valve uses.
GMC Integrated Brake Controller 38mike Electrical 1 06-27-2010 10:58 PM
Which trailer brake controller do you use and do you like it? redsdad Suspension - Brakes - Steering 3 02-02-2009 11:40 AM
04 silverado trailer brake problem shady4 Electrical 2 05-17-2008 09:57 AM
Electric brake trailer question? jezlearnin01 Suspension - Brakes - Steering 7 03-24-2007 11:58 AM
Brake controller install on 2000 chevy TurboS10 Electrical 0 02-13-2004 11:17 PM
