trailing arm on 86 trans am rearend - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-14-2011, 01:39 PM
ogre's Avatar
the 'Duracell Project'
my 58 chevy truck has an 86 trans am rear end in it.
the truck is lowered by flipping the axle and a 3'' c-notch in the frame.
when i take of under hard acceleration the drive shaft rubs a xmember.
i believe this is due to spring wrap under 1st gear acceleration, tilting the pumpkin.
the trans am was set up with coil springs, panhard bar and a single trailing arm running to the side of the back of the trans.
i'm thinking of leaving my set up as is and adding a trailing arm to prevent spring wrap and thus prevent the tilting of the rearend.
my question is: how far up should i make the trailing arm pivot?
option 1. front pin of the rear leaf springs. this is the natural pivot point of the rearend anyways. this point is also the xmember that rubs.
option 2. as far towards the back of the trans as i can get it. i'm thinking there will be some binding between the pivot of the leaf springs in suspension travel with having the pivot up front.
also should i use a link (like a sway bay link) or a pivot (like a rubber a-arm pivot)
this picture shows the rearend setup as is. the bed is on and the truck is driven daily.
you can also see the bolt holes for the swing arm mount on the front of the pumpkin.
the drive shaft is hitting the 2nd (painted) xmember, no real room to move it up or modify it.
Old 06-14-2011, 01:43 PM
ogre's Avatar
with the bed on i have minimal suspension travel, maybe 2.5''.
i had to add air shocks to keep off the bump stops.
yes i should redo the whole rear setup, but 3400 miles on the power tour
proved the air shocks are effective at keeping me off the bump stops
Old 06-16-2011, 12:22 PM
ogre's Avatar
anybody?
Old 06-16-2011, 01:49 PM
malc's Avatar
Living At The Speed Of Life
I´d go look at the stock setup on an 82 - 92 Trans Am or Camaro.
The swinging arm you speak of is in fact a torque arm anchored at the trans tailshaft in a rubber bushing.There were two trailing arms each side of the axle.
Would´nt your setup be better with traction bars, Cal-Tracs for example ?
Old 06-16-2011, 01:51 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
H'mmmm I am thinking...
Sam
Old 06-16-2011, 05:34 PM
SSedan64's Avatar
How did you route the Vent and what about the Gear lube level with the Housing flipped?
Old 06-17-2011, 09:56 AM
ogre's Avatar
malc: yes, i am referring to the torque arm not trailing arms. i figure traction bars would look silly on this truck. i also figure that i have the mount on the housing, i should use it. plus i have all the materials to build it on hand.
onemoretime: think harder.
sedan: i flipped the axle on top of the springs, same orientation. flipping the axle as you suggest would give me 4 speeds in reverse only.
looking at traction bar mounts; i will pivot at the front pin of the rear springs.
Old 06-17-2011, 11:09 AM
cal1320's Avatar
I would try to use the factory torque arm if possible. It bolts neatly to the axle and works great. If you think you need more strength you can box the torque arm. Makes it VERY strong. Up front you cannot bolt it rigidly to the x member or the suspension will bind. Arc of the springs vs arc of the torque arm. Build a shackle mount like the pic. It will allow free movement of the axle.
Old 06-17-2011, 11:58 AM
malc's Avatar
I think you need it longer, at least to the trans tail shaft like the original.
You need the axle to be going up and down a short "torque arm" will cause it to arc.
Old 06-17-2011, 12:16 PM
cal1320's Avatar
One other note. I would also use a heim joint at the x member shackle to arm connection. This will allow for any roll rotation without binding.
Old 06-17-2011, 12:22 PM
Wiki Edits: 3
That setup works wonderful and make the length of the arm so the front pivot is about at the front u-joint...and use the shackle with jonny joints or heim to allow for rotation of the rear end..
Sam
trailing arms on a 67 fbody freeskier Suspension - Brakes - Steering 2 02-10-2011 06:56 PM
Help needed for trailing arm application renfroe453 Suspension - Brakes - Steering 2 03-15-2009 02:48 PM
53 ford Trans & rearend Rob Graham Transmission - Rearend 3 07-22-2004 04:38 AM
How do I line up the trans to the rearend? wedamman Transmission - Rearend 2 09-07-2003 07:05 AM
73 duster trans and rearend... purplePeopLEater Transmission - Rearend 1 09-19-2002 01:01 PM
