tranny - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-07-2003, 06:06 PM
tranny
i have just bought a parts car for my 69 mustang and i noticed that it has an FMX transmission. the one bolted to my 351 right now is just a c4. i am wondering if it is worth it to put the fmx in it or just leav the c4. Any suggestions would be appriciated.
Old 09-08-2003, 06:00 PM
adtkart@aol.com
That is a hard question to answer. It depends on several factors. If the C-4 is working and you are not planning on racing and also not planning on having a trans rebuilt right now, leave it in there. I would not change it just for the sake of changing it. A c-4 will hold up just fine under normal conditions. As trans go, they are relatively easy and inexpensive to rebuild, with the key word being "relatively". The FMX, in stock form is heavy, more difficult and expensive to work on. Although they can be made relatively "bullit Proof", you have to find someone that really knows them to get those results. I personally wouldn't change them unless I really needed to.
Old 09-20-2003, 10:50 AM
k2mooch's Avatar
C-4
Hey, I'm a new member and this is my first post. I have some tranny issues with my '69 coupe too. Anyway, after asking a few guys in the local mustang club, they gave me some feedback on the FMX. Apparently, it stands for Ford Motor eXperimental. It is a very rare tranny that usually bolts up to the 351's. Rebuild cost and parts for this will cost you. If you can make the c-4 work, I'd say go with that one.
I have no idea about the performance issuse of either of these since I'm just learning about it myself. But c-4 may be easier on the wallet. Lemme know how it works out.
Old 09-20-2003, 03:04 PM
adtkart@aol.com
Re: C-4
It amazes me some of the information that I read on these boards. I don't know that FMX was experimental. I have seen many of them in larger cars and trucks. Since I have probably only rebuilt maybe 50 of them, I am no expert, but believe they are very reliable if done right. The fact that you may not be able to find one of the young guys doing transmissions, that knows anything about them does not mean that they aren't any good. There were alot of older trans that were very dependable that were replaced with junk to save weight and fuel.
I will say, however, if I had a Mustang that wasn't being built with high HP, I would stay with the C4. It is better to stay original and is also simpler for someone that doesn't know what they are doing. Just have to make sure everything is spotless when working on it. Very suseptical to any type of dirt.
