Tranny Adapters? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2008, 03:34 PM
Tranny Adapters?
Hello all...
Anyone know if its possable to adapt a tranny out of a 351m to a 351c? is there a adapter kit you can buy? or should it just bolt up to it?
Thanks for your help
Carl
Old 01-14-2008, 09:39 PM
327NUT's Avatar
Unknown to me but give www.wilcap.com a hoot, they've been in the adapter bizz for 50 yrs or so. They're in Pismo Beach, Ca.
Old 01-14-2008, 09:47 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Originally Posted by RenoValron
Hello all...
Carl
generally an adapter is not manufactured when a bell housing / trans case already is manufactured with the proper bolt pattern.
351c should have a small block Ford pattern.... the 351m should be a big block pattern.
Tranny to cross member alignment issue Blue67Camaro Transmission - Rearend 5 01-14-2008 02:24 PM
!993 T-Bird Tranny Re-build Mike in Canada Transmission - Rearend 8 06-29-2007 08:09 PM
Pulling motor/ tranny 66 C10 66thom Engine 6 10-27-2003 10:46 AM
Tranny fluid heating up engine??? black66 Engine 1 07-13-2003 10:18 PM
88 AOD tranny problems rflud Transmission - Rearend 9 02-17-2003 05:53 PM
