Tranny cooler lines - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-21-2012, 05:59 PM
Tranny cooler lines
I just finished rebuilding my 700r4 out of a 89 suburban and I'm in the process of hooking up the external cooler lines. Is there supposed to be an o ring that fits on the tranny side? It's a stock application with the flared steel lines.
Thanks
Old 01-23-2012, 08:36 PM
Crosley's Avatar
Wiki Edits: 1659
Thanks
if you are talking about a rubber o-ring inside the fitting where the steel line threads into? Nope , no O-ring there. Flared fitting design seals up
Old 01-24-2012, 06:23 AM
Crosley:
Thanks for the response. No o-ring it is.
67 Ford Truck Tranny cooler lines questions Jeffemtb Transmission - Rearend 2 09-30-2010 07:49 PM
T-350 cooler lines, in & out? s10mk Transmission - Rearend 2 05-23-2010 12:32 PM
cooler lines ragincajun19 Transmission - Rearend 10 05-01-2007 02:01 PM
C6 cooler lines, which is in and which is out? MM in NM Transmission - Rearend 2 01-26-2006 09:18 PM
Th-350 cooler lines..where do they go V8 S-10 Transmission - Rearend 3 09-17-2003 07:39 AM
