tranny cooler temp - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-10-2006, 01:11 PM
tranny cooler temp
what is operating temp on a tranny........is there a minimum temp it should reach.........like for evaporating any condensation or water?....I am still contemplating buying a cooler but dont want to hurt anything either, I think there is a minimum temp to get to but dont know what it is.....I live in ohio, and it does get cold here...........primary reason is I have the 4L60 in a 91 olds 88 and these I have heard are extremely expensive to rebuild so the idea is to make it last
Old 09-10-2006, 02:05 PM
malc's Avatar
Living At The Speed Of Life
Here´s a chart showing trans temp/failure.
Without using a rad with the trans oil going though it my trans usually gets up to 180º and stays there, even in the hot weather we´ve had.
I do have a 8 x 11 B/M cooler in front of the rad for the trans and an auxilliary cannister filter. Fluid through the cooler is controlled by a 180º thermostat. The thermostat on startup allows 10% of the fluid to flow through the cooler and opens fully at 180º.
Old 09-10-2006, 02:41 PM
wow how did you do a thermostat???..I would like to see that...If i get a thermostat then I could get a big cooler........just have the burning question........what temp should be a minimum requirement
Old 09-10-2006, 04:00 PM
malc's Avatar
Here is a pic of my trans and oil coolers, the trans cooler is to the left.
The thermostat is to the left of the cooler.
This is an old pic, the coolers now sit further back up against the rad.
I´ve given a link to an engine oil thermostat, the trans one is the same,
I could´nt find the trans version.
(´scuse the tatty appearance)
Old 09-10-2006, 05:21 PM
interesting.........should be very easy to hook up, although its hard to tell where the lines go as a schematic, but the thermostat looks like a fuel pump
Old 09-11-2006, 04:33 AM
malc's Avatar
Here´s the paperwork that came with the trans thermostat
Oil temp causes engineczar Engine 5 07-12-2006 06:49 AM
2004R tranny sotxpanrider Transmission - Rearend 0 05-20-2006 09:49 PM
Oil Temp / Cooler TBull Engine 11 06-24-2005 01:38 PM
rad/trans cooler question Toyman Engine 3 06-07-2005 02:48 PM
Engine oil cooler questions??? Blown72Camaro Engine 11 05-12-2004 10:16 AM
